Thread Number: 39043
Anyone Experience this while polishing aluminum |
Post# 414404   9/29/2019 at 11:34 (1,642 days old) by rodknock95 (Salem, Missouri)   |   | |
I polished this with Flitz and you can see see swirls of imperfections or something. Like the aluminum has something mixed in it. What have our expert polishers done about this? Blaze |
Post# 414406 , Reply# 1   9/29/2019 at 11:40 (1,642 days old) by Lesinutah (Utah)   |   | |
Post# 414409 , Reply# 3   9/29/2019 at 12:25 (1,642 days old) by rodknock95 (Salem, Missouri)   |   | |
Post# 414413 , Reply# 4   9/29/2019 at 14:03 (1,642 days old) by Lesinutah (Utah)   |   | |
Post# 414414 , Reply# 5   9/29/2019 at 14:45 (1,642 days old) by rodknock95 (Salem, Missouri)   |   | |
That was just using flitz with a buffer wheel |
Post# 414416 , Reply# 6   9/29/2019 at 15:19 (1,642 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Yes, a buffer wheel can still create friction and burn into the metal. Were you pressing too hard perhaps? To my knowledge Flitz is not a polishing wax that you use with a buffing wheel, it's very viscous (watery) and should only be done with a microfiber rag.
For metal polishing you want to use polishing sticks/bars, and preferably a hand or bench buffer (after grinding the damage from the metal if need be). I always liked this video, its nice and slow paced and easy to follow: Before I started polishing I bought a junky old 1960's Royal hand vac to practice metal polishing on and get a feel for the tools, before I work on the real serious stuff. That way if I mess up, no big deal. Like Les said, you can fix this buy re-sanding the metal out and starting over it again, and it can be cleaned out. Good luck! |
Post# 414418 , Reply# 7   9/29/2019 at 15:58 (1,642 days old) by rodknock95 (Salem, Missouri)   |   | |
Ill do one and it turns out great and the next----so so. I was using buffing wheels made of cotton on a Dewalt drill. Possibly its going too fast and im grinding down on it too hard |
Post# 414423 , Reply# 8   9/29/2019 at 18:19 (1,642 days old) by MadMan (Chicago, IL, USA)   |   | |
From the picture, it kinda looks like it was clear coated, and the polishing took some of the clear coat off.
The second picture, though, really just look like normal wavy imperfections from the factory. Either way, I'll second Les here, you need to sand with many grits going up to 2000 or 3000. Your starting grit really depends on the depth of the imperfections. I would start with maybe 600, then go up in steps, by the time you get to 1k or 2k, you should see whether or not you got it right. If not, start all over with lower than 600. You might try just buffing it with a cotton wheel rouge first, though. It's really hard to tell from the pictures. |
Post# 414450 , Reply# 9   9/30/2019 at 08:00 (1,641 days old) by bnsd60m9200 (Akron OH)   |   | |
polishing rouge comes in solid sticks. flitz is a polishing compound to be used manually, not with a wheel. its like clay bar for cars. i dont use any of those compounds anymore and havent for many years.
i dry sand at 220 grit with a palm sander. then 320,400,600,800,1000 and 2000 wetsand with automatic transmission fluid as the wet agent. i sand it opposing directions every other grit (left right, up down) after that i use 000 steel wool for a mirrory luster then turtle wax polishing compound. then i wax it with mequiars ultimate paste wax. wax it every year (once) and youll never have to re polish. i used wheels early on and just dont anymore, its far too uncontrollable and messy compared to by hand. |
