Thread Number: 39012
Hoover Model 700 Brush Roll Brush Strips? |
Post# 414071 , Reply# 1   9/21/2019 at 02:24 (1,678 days old) by Lesinutah (Utah)   |   | |
Post# 414079 , Reply# 2   9/21/2019 at 13:43 (1,677 days old) by BetaM64 (Avonmore, Pennsylvania, USA)   |   | |
Turns out, he is sold out. So the search continues. Is there a model number I can search for? I checked with the serial/part numbers on the strips and came up empty handed. Is there another model or type that will fit, maybe with some slight filing or modification? |
Post# 414083 , Reply# 3   9/21/2019 at 15:21 (1,677 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
What "Run" is your sweeper? The 700 had different brushrolls throughout the run.
First run cleaners used 8639 (long) and 8640 (Short). Second Series used 8955 (long) and 8956 (Short). Alternate first series style was 86187 (long) and 86188 (short). Remove the old brush inserts, the number may be stamped inside. |
Post# 414084 , Reply# 4   9/21/2019 at 15:25 (1,677 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 414109 , Reply# 5   9/22/2019 at 09:33 (1,676 days old) by bikerray (Middle Earth)   |   | |
You do know that you can take the brush strips out and turn them around for a little longer wear, unless they're past that point.
To get the brush strip out take a screwdriver just press the end by the belt pulley down and under the belt pulley and the other end should just pop up out of the agitator. The brush strip should have arrows on it marked new and used. |
Post# 414426 , Reply# 6   9/29/2019 at 19:08 (1,669 days old) by bikerray (Middle Earth)   |   | |
the 8639 & 8640 brush strips were used in the 543 and 700 first series
the 8955 & 8956 were used in the 543 2nd and 3rd series, 575 - 700 2nd series, 725 1st series the 86187 & 86188 were used in the 543 and 700 1st and 2nd series, 543 3rd series, 575-725-750-800-825-900-925 Hope that helps
Post# 414427 , Reply# 7   9/29/2019 at 19:27 (1,669 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Post# 414451 , Reply# 8   9/30/2019 at 08:35 (1,668 days old) by bikerray (Middle Earth)   |   | |
In the manual it tells you that if you put a card across the rug plate and the bristles don't at least touch the card it's time to turn them around or replace them. That's on the agitators that don't have an adjustment for the agitator.
On models that have an adjustment at each end of the brushroll i.e. 102, 103, 105, 541 you just move the adjustment to the next hole in the tab to lower the brushroll to the floor and take up the wear. |
Post# 414457 , Reply# 9   9/30/2019 at 14:19 (1,668 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Post# 414549 , Reply# 10   10/2/2019 at 21:29 (1,666 days old) by bikerray (Middle Earth)   |   | |
Here's the two pages from the 700 owners manual that cover the belt and brush strips. According to my price list those brush strips were at a nominal cost of 50 cents for the long strip and 45 cents for the short strip.
Post# 464810 , Reply# 11   7/24/2023 at 23:15 (275 days old) by Chris631 (Nebraska )   |   | |
Unsure if anyone still needs them but I have acquired a few strips # 86187 |
Post# 465076 , Reply# 12   8/3/2023 at 17:15 (265 days old) by anthony (leeds uk)   |   | |
Post# 465079 , Reply# 13   8/3/2023 at 22:47 (265 days old) by Chris631 (Nebraska )   |   | |
Don't think that would be too big of a problem. Would have to guide me through the international shipping process but I'll it can't be too bad. Which are you wanting? I have 86187 and 86188 |
Post# 465138 , Reply# 14   8/6/2023 at 13:55 (262 days old) by anthony (leeds uk)   |   | |
I have removed them and taken pictures [can you tell from them]one of them has a number on it . these brush strips are virtually impossible to get over here in the Uk so getting some new ones would be fantastic .Kind regards
Antony |
Post# 465140 , Reply# 15   8/6/2023 at 14:53 (262 days old) by Chris631 (Nebraska )   |   | |
Not completely sure but they definitely look similar. I have 2 86188 and 8 of the 86187.
Post# 465141 , Reply# 16   8/6/2023 at 17:23 (262 days old) by anthony (leeds uk)   |   | |
they certainly look the same .I guess its just a matter of the measurements. my old ones measure as follows .Long one 145mm .short one 110mm
Post# 465151 , Reply# 17   8/7/2023 at 02:44 (262 days old) by Chris631 (Nebraska )   |   | |
Post# 465155 , Reply# 18   8/7/2023 at 10:25 (261 days old) by anthony (leeds uk)   |   | |
Post# 465156 , Reply# 19   8/7/2023 at 11:08 (261 days old) by Chris631 (Nebraska )   |   | |
You tell me a price because I couldn't be more clueless. And I will get into checking on how to get them there. Hopefully someone else can chime in if they've ever done it |
Post# 465162 , Reply# 20   8/7/2023 at 16:39 (261 days old) by anthony (leeds uk)   |   | |
Post# 465236 , Reply# 21   8/10/2023 at 22:49 (258 days old) by Chris631 (Nebraska )   |   | |
Sent you an email Anthony! |
