Thread Number: 38812
Rainbow D4 Power Switch |
Post# 412408 , Reply# 1   8/5/2019 at 08:31 (1,697 days old) by rugsucker (Elizabethton TN)   |   | |
Check carbon brushes first.May have burned/broken spring.If taken care of few problems are major.Good luck. |
Post# 412417 , Reply# 2   8/5/2019 at 14:11 (1,697 days old) by dysonman1 (the county)   |   | |
Remove (carefully) the rubber gasket surrounding separator area.
Remove four silver screws and lift off plastic bottom cover. Remove four silver screws (use long screwdriver)to separate top cover from bottom. You are now into 'the works'. Remove the plastic motor cap and check motor brushes. You can now also check cord leads as well as switch connection. When reassembling, use glue to glue gasket where you removed it from separator area. |
