Thread Number: 38770
Rainbow AquaMate Carpet Shampoo Alternatives |
Post# 411895   7/22/2019 at 15:55 (1,711 days old) by mmcphee (Lisbon Falls, Maine)   |   | |
Does anyone have any good alternatives to the Rainbow AquaMate carpet shampoo? I currently have 2 1 gallon bottles of Rug Doctor Oxy carpet shampoo and I'm going to be buying the Rainbow AquaMate 2 soon. I'm wondering if the Rug Doctor shampoo is compatible. I asked Rainbow themselves and they said it wasn't' compatible but I think they just want to push their chemicals.
Long story made shorter, what do you guys use in your Rainbow AquaMate? |
Post# 411898 , Reply# 1   7/22/2019 at 16:31 (1,711 days old) by mark40511 (Lexington, KY)   |   | |
I sometimes wonder if the chemicals would be compatible. But 2 things come to mind that would make me AFRAID to use another chemical in the Aquamate (unless it was white vinegar something like that.....The fact that you're only using cool water and the possibility that since that chemical is not designed for the rainbow, if it would gum up the aquamate? Although really all you would need to do is flush with water after done, which I do anyway. Then there's the foaming issue. If you're using rug doctor shampoo or something like that in a rainbow, will it foam too much while the extracted water is swirling in the basin? That would be my biggest worry. You might try adding a small amount and mixing it with water. My gut tells me it wouldn't hurt a thing.
Post# 411923 , Reply# 2   7/23/2019 at 02:19 (1,710 days old) by rivstg1 (colorado springs)   |   | |
Post# 411924 , Reply# 3   7/23/2019 at 06:46 (1,710 days old) by Blackheart (North Dakota)   |   | |
I'd think Lindhaus Extractaire would work. It's an organic alcohol formula and leaves no residue so I can't imagine it'd gum up the lines. I've been using it for years now.
Post# 412053 , Reply# 4   7/26/2019 at 17:07 (1,707 days old) by Dysonman1 (the county)   |   | |
