Thread Number: 38734
Now I did it! Royal PowerCast |
Post# 411552 , Reply# 2   7/15/2019 at 23:05 (1,718 days old) by rivstg1 (colorado springs)   |   | |
Post# 411553 , Reply# 3   7/15/2019 at 23:50 (1,718 days old) by electrolux137 (Los Angeles)   |   | |
~ The Powercast models are highly styled and retro-looking. But they're beasts -- heavy and unwieldy and hard to move around. This series of machines was a big flop and a huge money-loser for Royal. And that's a pity because they really are beautiful -- and powerful.
Post# 411554 , Reply# 4   7/16/2019 at 00:03 (1,718 days old) by Lesinutah (Utah)   |   | |
Post# 411594 , Reply# 6   7/16/2019 at 23:10 (1,717 days old) by Lesinutah (Utah)   |   | |
Post# 411616 , Reply# 9   7/17/2019 at 16:01 (1,716 days old) by Lesinutah (Utah)   |   | |
Post# 411673 , Reply# 11   7/18/2019 at 18:28 (1,715 days old) by Lesinutah (Utah)   |   | |
Drain snakes work for cleaning hose. I have but wouldn't recommend is water. You put hose in one end and seal with hand it eventually unclogs the hose. I run water through and seal one side) I do this a few times making sure the hose is free of debri. If you have a compact or shop vac with a blower they work.
Just pressure eventually unclogs hose. Les |
Post# 411796 , Reply# 14   7/20/2019 at 19:35 (1,713 days old) by Lesinutah (Utah)   |   | |
If it's a bypass unit which royal commercial was bypass. The hose will disconnect outside power nozzle probably on the right side. The left side would be the end of the hose and could be disconnected there.
The hose by brushroll goes directly to the bag. You can take bag off and use a blower and it will clean out. If it has this bag housing blow it out too. Les |
Post# 411803 , Reply# 15   7/20/2019 at 20:01 (1,713 days old) by fantomfan57 (Central Texas)   |   | |
I think you are talking about a completely different Royal model based on your suggestions. This is a Royal Powercast. Does not look anything like the other Royal metal upright models. |
Post# 411804 , Reply# 16   7/20/2019 at 20:39 (1,713 days old) by Lesinutah (Utah)   |   | |
Post# 411820 , Reply# 17   7/21/2019 at 00:46 (1,713 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 411824 , Reply# 18   7/21/2019 at 01:58 (1,713 days old) by fantomfan57 (Central Texas)   |   | |
That is funny, but I will find out where they go. After all, I did not completely disassemble this unit. |
Post# 411841 , Reply# 19   7/21/2019 at 11:00 (1,712 days old) by kirbyklekter (Concord,Ca.)   |   | |
I've had screws fall out of vacuums during dis-assembly and dat-assembly, (sorry), that didn't even go to that machine, someone just thought it was missing and added a screw where it was never intended. So there's that. |
Post# 411847 , Reply# 20   7/21/2019 at 14:36 (1,712 days old) by Lesinutah (Utah)   |   | |
Post# 419822 , Reply# 23   2/10/2020 at 21:47 (1,508 days old) by rivstg1 (colorado springs)   |   | |
