Thread Number: 38731
Discovery 2 loud |
Post# 411506   7/14/2019 at 17:14 (1,744 days old) by compactc9guy (Bathurst NB)   |   | |
My Electrolux Discovery 2 was a dusty mess when i got her a few years ago.
Now it runs fine nto hot but is a lil louder as time goes on .(use whit no bag didnt help before i got it)Could i lube the motor bearing whit 3-1 oil or should i use w30 ND oil ? Electrolux Discovery 2 upright suction could be improve good on carpet not much on the hose id like to make it run smoother again . |
Post# 411507 , Reply# 1   7/14/2019 at 18:47 (1,744 days old) by compactc9guy (Bathurst NB)   |   | |
Post# 411513 , Reply# 2   7/14/2019 at 22:04 (1,744 days old) by MadMan (Chicago, IL, USA)   |   | |
Well, you'll just have to deal with the oil smell. If the armature is oily, it's not a problem. If the commutator is oily, it needs to be cleaned, and you will also have to clean the brushes. Remove the brushes, wet a paper towel with any alcohol and wipe the commutator all the way around. Wipe down the brushes and make sure there is no oil residue on them before reinstalling.
That's it. |
Post# 411514 , Reply# 3   7/14/2019 at 22:13 (1,744 days old) by Lesinutah (Utah)   |   | |
Post# 411520 , Reply# 4   7/14/2019 at 22:44 (1,744 days old) by compactc9guy (Bathurst NB)   |   | |
Well thank you !!
MadMan Il do that tomorrow had a oil smell (3 in 1 sewing machine oil clear ) but lordy did it ran smooth and groom so much better but also had a smell so i sutt off fast-. And also on run down just a smooth sound no rattle no clic i was impress i will clean it up in the morning thank you .That just save me vacuum mind you its a 20$ vac from a yard sale but il give her a go. |
Post# 411521 , Reply# 5   7/14/2019 at 23:05 (1,744 days old) by compactc9guy (Bathurst NB)   |   | |
Is this clean enough
Post# 411522 , Reply# 6   7/14/2019 at 23:17 (1,744 days old) by Lesinutah (Utah)   |   | |
A little bit of residue on bearing.
Pic 2 use 0000 grit if maticulouus. Les |
Post# 411523 , Reply# 7   7/14/2019 at 23:20 (1,744 days old) by compactc9guy (Bathurst NB)   |   | |
Post# 411524 , Reply# 8   7/14/2019 at 23:30 (1,744 days old) by compactc9guy (Bathurst NB)   |   | |
Post# 411540 , Reply# 9   7/15/2019 at 16:29 (1,743 days old) by electroluxxxx (……)   |   | |
use oil. go to the automotive store and grab some blue brake and bearing grease. oiling the bearing will destroy it. Ball Bearings-Grease Sleeve Bearings- oil |
Post# 411541 , Reply# 10   7/15/2019 at 16:35 (1,743 days old) by compactc9guy (Bathurst NB)   |   | |
Post# 411546 , Reply# 11   7/15/2019 at 20:55 (1,743 days old) by electroluxxxx (……)   |   | |
its a ball bearing, those motors have 2 ball bearings. The canisters usually use an upper sleeve bearing and a lower ball bearing, i have serviced quite a few of these and have quite a few of them as well. |
Post# 411547 , Reply# 12   7/15/2019 at 21:19 (1,743 days old) by compactc9guy (Bathurst NB)   |   | |
Post# 411556 , Reply# 13   7/16/2019 at 00:23 (1,743 days old) by MadMan (Chicago, IL, USA)   |   | |
It's really not the end of the world. If oiling the ball bearing silenced it, it was likely dry already. In other words, at the end of its service life already. If the bearing is not open on the sides, I'd just leave it alone until it quits, then get a new one. If it's an open frame bearing, pack it with some general purpose automotive grease from the parts store.
In fact, if the ball bearing is a sealed bearing, likely the oil you put on it barely penetrated it, and it's probably fine. |
Post# 411561 , Reply# 14   7/16/2019 at 08:25 (1,743 days old) by kloveland (Tulsa)   |   | |
Post# 411578 , Reply# 15   7/16/2019 at 16:16 (1,742 days old) by compactc9guy (Bathurst NB)   |   | |
Happy to report my Electrolux Discovery 2 is running like a champ !
No smell no noise works good smooth motor so glad.
