Thread Number: 38597  /  Tag: Recent Vacuum Cleaners from past 20 years
,Filter Queen motor replacement
Post# 410298   6/10/2019 at 10:06 (1,772 days old) by rickpretired (Alabama)
The 4 wire motor on my Filter Queen triple crown vacuum-Red died. I was sent the newer 5-wire motor as a replacement. Absolutely NO wiring instructions came with the new motor. Color codes match for the red, yellow, blue, and black. However wiring the white “extra” wire to the multiple white wire connection would ‘appear ‘ to bypass the high/low switch. I’m hesitant to SMOKE TEST any configuration until I get some expert advice, verifying the connections for the White and Black wires. My biggest concern is the fact that you ABSOLUTELY CANNOT replace the newer 5-wire motor with the older 4-wire motor.
Post# 410310 , Reply# 1   6/10/2019 at 19:36 (1,771 days old) by compactc9guy (Bathurst NB)
compactc9guy's profile picture
have you tried googling the filter queen motor ? il look at some older post be back to ya soon .
Post# 410311 , Reply# 2   6/10/2019 at 19:39 (1,771 days old) by compactc9guy (Bathurst NB)
Read this tread for wire info .
CLICK HERE TO GO TO compactc9guy's LINK
Post# 410315 , Reply# 3   6/10/2019 at 22:51 (1,771 days old) by MadMan (Chicago, IL, USA)
madman's profile picture
If the old motor did not have a white wire, it's not a good idea to assume that the new motor's white wire is a common (white) wire. Unfortunately I don't know much about these machines, so that's about all I can say. You could identify the wires manually. Hopefully you still have the old motor for comparison.
