Thread Number: 38585
Finally got a Heritage 84....but.... |
Post# 410232   6/8/2019 at 20:59 (1,755 days old) by rodknock95 (Salem, Missouri)   |   | |
I bought a Heritage 84 Kirby, but it doesn't say it on the nozzle, but has everything else saying it...so I assume it has had the nozzle changed out at some point |
Post# 410233 , Reply# 1   6/8/2019 at 21:25 (1,755 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 410237 , Reply# 2   6/8/2019 at 23:42 (1,754 days old) by rodknock95 (Salem, Missouri)   |   | |
Underneath the bump strip is a white sticker with a serial number matching the serial number on the main motor, so I guess its original. So some got the label and others didn't Who would have thunk it Blaze |
Post# 410241 , Reply# 3   6/9/2019 at 06:03 (1,754 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 410245 , Reply# 4   6/9/2019 at 08:44 (1,754 days old) by rodknock95 (Salem, Missouri)   |   | |
1840200505 is the number |
Post# 410246 , Reply# 5   6/9/2019 at 08:46 (1,754 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 410258 , Reply# 8   6/9/2019 at 16:02 (1,754 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Blaze,
It's time I have you look at these pages from my Omega service book, again, about fan replacement. The fan is reverse-threaded; to get it off would mean having to use an ice pick or a special armature removal tool. ~Ben |
Post# 410278 , Reply# 10   6/9/2019 at 22:44 (1,754 days old) by Lesinutah (Utah)   |   | |
They might have put a armature from a different model. The armature fans do come off. If you are so inclined with a vice and a drill press. Put a hole in it. The Carnage of ripping it out is not advised.
I'm not sure but slowly prying.apart it will pop out eventually. Like c clamps maybe 4 c clamps use 2 screw drivers on each side pulling up I'd imagine the armature would pop up. One model has bearing plate built in to the motor housing. Omega classic 3 or tradition. The only thing I remember is I did a cb1 cr1 and cb3 at once and had cb2 for parts. I messed up all of them as I thought they were same body and none were the same. Good luck Les |
