Thread Number: 38556
Need Help Hoover Windtunnel Max Belt won't shut off in upright position |
Post# 409987 , Reply# 1   5/31/2019 at 09:59 (1,763 days old) by broomvac (N/A)   |   | |
You are talking about the Max bagged upright you posted a picture of in the other thread, right?
I have good news and bad news. The good news is that your vacuum is working as it should. The bad news is, well, that your vacuum is working as it should. See, I believe that these are not designed to shut off the brush when the vacuum is upright. Hoover models with the later pedal design would do this, but yours has the early design. Later vacuums had a peg on the side of the main body which would depress the pedal temporarily when the vacuum was upright. With yours, the only way to turn off the brush is by manually pressing the pedal. |
Post# 410025 , Reply# 3   6/1/2019 at 11:02 (1,762 days old) by broomvac (N/A)   |   | |
Post# 410026 , Reply# 4   6/1/2019 at 11:03 (1,762 days old) by broomvac (N/A)   |   | |
Post# 410032 , Reply# 5   6/1/2019 at 18:34 (1,761 days old) by CMBCOOL01 (Texas)   |   | |
This model is actually suppose to disengage when it's the upright position and up till recently did so it stopped doing so at the same time the pedal stopped doing so
Post# 410034 , Reply# 6   6/1/2019 at 18:40 (1,761 days old) by broomvac (N/A)   |   | |
Post# 410037 , Reply# 7   6/1/2019 at 21:01 (1,761 days old) by CMBCOOL01 (Texas)   |   | |
No issue i thank you for actually responding to help at all |
