Thread Number: 38452
Kirby 518 restoration COMPLETED |
Post# 409183   5/7/2019 at 19:33 (1,814 days old) by Kirbytex85 (Houston, TX)   |   | |
After several months of cleaning/polishing/rebuilding I’ve finally finished the restoration on this 518. I tried to keep it as original as possible and reuse most of the old parts. I replaced the bearings and had to source the light cover from a D80. The light cover trim was replaced and I found the cord online. On the bag, it is the genuine Kirby replacement for these models and wasn’t easy to locate, I then created the logo, tried to match the red to the trim then had it screen printed onto the bag. Too bad you can’t find the gray bags anymore. I figured the red would look better than solid black behind the logo. I get it’s not 100% original but since you can’t find the originals I figured this would work.
Only issue now is the wires on the light socket came apert so I’ll have to source that and address. Hope y’all enjoy seeing the restored 518. I look forward to your thoughts. |
Post# 409184 , Reply# 1   5/7/2019 at 19:44 (1,814 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 409186 , Reply# 2   5/7/2019 at 19:54 (1,814 days old) by Lesinutah (Utah)   |   | |
That is a beautiful makeover. I'd only suggest red wheels or paint red wheels.
That is a one of a kind bag. I have a bag that is original but it's 519 560. I still think your bag has wow factor. I'd recommend ditching safety switch have vacuum turn on and off with power switch. This way a classic 3 red hose would match and work on this machine. The lights quick solder job. If you have to cut off order used assembelly solder old to new heat shrink over it then put black cover over and light will be good as new. Les |
Post# 409189 , Reply# 3   5/7/2019 at 20:19 (1,814 days old) by Kirbytex85 (Houston, TX)   |   | |
Post# 409191 , Reply# 4   5/7/2019 at 20:43 (1,814 days old) by Lesinutah (Utah)   |   | |
They make no grey bags. The material on the black bag is heavy duty. I think the color is perfect as it's a Kirby bag that's way heavier duty than original bag. I really like it alot. I thought about doing a black bag with d80 logo similar to yours. I'm not sure black and greens look as sweet as black and red though.
I'd say coolest bag I have seen. Les |
Post# 409201 , Reply# 5   5/8/2019 at 06:00 (1,813 days old) by Kirbytex85 (Houston, TX)   |   | |
Post# 409203 , Reply# 6   5/8/2019 at 08:40 (1,813 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 409208 , Reply# 7   5/8/2019 at 12:44 (1,813 days old) by Kirbytex85 (Houston, TX)   |   | |
Post# 409294 , Reply# 8   5/10/2019 at 01:18 (1,812 days old) by Kirbyrama (Pennsylvania)   |   | |
This turned out great. Wonderful idea for a bag logo. |
Post# 409295 , Reply# 9   5/10/2019 at 02:38 (1,812 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 409399 , Reply# 10   5/13/2019 at 13:43 (1,808 days old) by scudo (uk)   |   | |
Beautiful, very well done. |
Post# 409539 , Reply# 11   5/17/2019 at 14:05 (1,804 days old) by ABCVacPlacentia (California)   |   | |
What's the diameter of the Kirby logo on your reproduction bag? |
Post# 409552 , Reply# 12   5/17/2019 at 22:54 (1,804 days old) by Lesinutah (Utah)   |   | |
It looks 3.5"-4"
Take a pic of the belt lifter pic and blow it up 3 time's. The 560 belt lifter Is the starburst belt lifter. Notice the bag topper has a small red piece of material. It's cuurdoroy I'd go dark grey maybe get like a waterproof spray add some glitter or clear coat paint mixed with sparkles. The 513-560 bags have same greyish color. Curdouroy material has fabric lines making replication almost impossible. Finding odd grey and getting sparkles idk. My 1920s royal bag is burlap. They used house paint. You could tape off and use house paint. The creator of the thread just install a zipper and could install fill tube assembelly himself. I'm just throwing suggestions out there. Making a bag from scratch isn't easy. Getting a black Kirby bag and going from there is easier. Like the part of the bag that goes over emtor you really and I mean really probably not be able to replicate it. I talked to alot of people and I replicated it. Just the small details like what you use on top of the bag has to be correct. It can be done but buying a bag installing zipper will save you alot of time. I rambled enough. Les |
Post# 409754 , Reply# 13   5/24/2019 at 21:35 (1,797 days old) by DoraDave (Memphis)   |   | |
Post# 411640 , Reply# 14   7/17/2019 at 23:27 (1,743 days old) by Kirbytex85 (Houston, TX)   |   | |
Post# 411641 , Reply# 15   7/17/2019 at 23:38 (1,743 days old) by compactc9guy (Bathurst NB)   |   | |
