Thread Number: 38386
Newest Member to My Kirby Family - 511 |
Post# 408533   4/23/2019 at 14:17 (1,829 days old) by dandagreer (Nashville, TN)   |   | |
Excited about my newest Kirby find - a 511! It was a 2011 Factory Rebuild, but, as is usually the case, was "tan-ified" to their now-standard parts. The cool part was, the internals were in near perfect shape. And the finish was beautiful -- all except for the emptor. It looks like they completely ignored it.
I used automotive vinyl paint with adhesion promoter, and painted the handle grip, bumper, and head light trim back to their original grey, then got some black wheels on Ebay to look more original. I've seen reproduction bags for these models on Ebay and here, but I can't seem to find who. Does anybody know who does those? I would love a reproduction gray bag with the old Kirby logo on it. |
Post# 408561 , Reply# 1   4/23/2019 at 22:45 (1,828 days old) by Vac-o-matic (Saint Louis, Mo.)   |   | |
Nice job! It's weird about the emptor..they usually look better than the machine. |
Post# 408610 , Reply# 3   4/25/2019 at 00:53 (1,827 days old) by Lesinutah (Utah)   |   | |
I'm going to have to hit you up on painting trim. That's probably best I've seen. If you didn't tell us it was painted I wouldn't believe you.
When they rebuild they put a 4 amp mototin and the power switch gets changed to 513 chrome foot switch. Is motor 4 amp and Im guessing you changed switch back to original. Very nice. Les |
Post# 409299 , Reply# 4   5/10/2019 at 06:56 (1,812 days old) by Dandagreer (Nashville, TN)   |   | |
No, actually it came back from Kirby like that with the toggle switch. I love it. And, yeah, painting the trim was pretty easy. I didn’t even remove the bumper or the handle grip, but I did remove the headlight trim. I masked it, used an adhesion promoter, and about 6 coats of vinyl spray paint. Turned out perfectly!
Post# 409419 , Reply# 7   5/13/2019 at 23:00 (1,808 days old) by kirbyklekter (Concord,Ca.)   |   | |
I typed the wrong model number, it's getting late. Your 511 looks great! Sorry, Billy |
Post# 409446 , Reply# 8   5/14/2019 at 21:59 (1,807 days old) by Lesinutah (Utah)   |   | |
I have a bag setup sealed and it has a twist. Let's say the first bag of it's kind sold for eBay record. The buyer asked for 508-520 513 517 560 versions. It would have zipper or no zipper but the setup is not Kirby's inner tube assembelly it's a better hose. It's better than anything on the market. The problem is if you reproduce a bag looking original they will not want the zipper. If you did bag assembelly access bag through the top . This keeps the bag as original as collectors would want it.
If you are making bags the thing that goes around the emtor you will not find without luck. The top is easier to find. I do have assembled bags. The black fill tube have flaws in cannister mode they kink. There is alot of research I have put into it. I would not put zipper on The bags but inside and pull bag topper off to change bag. People would want original bag. They want it more than modern bagging. Les |
Post# 409447 , Reply# 9   5/14/2019 at 22:14 (1,807 days old) by Lesinutah (Utah)   |   | |
Post# 409462 , Reply# 11   5/15/2019 at 06:54 (1,807 days old) by Dandagreer (Nashville, TN)   |   | |
Post# 409486 , Reply# 12   5/15/2019 at 18:43 (1,806 days old) by Lesinutah (Utah)   |   | |
The full tubes from heritage Al the way through avalir are black. You put sentria 2 fill tube on any vaccuum prior to classic(I believe emtor or different bag Dynamics) when you take off handle and use portable handle the tube kinks cutting off flow through the tube. I have a setup and a few bags with my version of the fill tube and it works.
You can use heritage mini emtor but mine has better airflow and I use sentria 2 topper for newest Kirby HEPA bags. Les |
Post# 409501 , Reply# 14   5/15/2019 at 23:09 (1,806 days old) by Lesinutah (Utah)   |   | |
I'm not being brash but this took me about 4 months to find correct part. I do plan to sale.
I have a ribbon like material that is what they use to make tents. It's sewn on the top of the bag and loops through f adaptor top and snapping where it originated. I use f type adaptor and my tubing. I cut Lexan glass making a plate to sit on the emtor. Lexan is really really hard to cut my huge hammer drill with correct hole saw bit. It torques the Lexan and it rips up your elbows. I'm a big very strong man. It's quite dangerous. I have 2 items I attach Lexan to fill tube. I sale them where you just glue on top of emtor. This makes air tight seal. The Lexan bits I bought a few $15-$20 a piece. You have to get correct depth of Lexan. |
Post# 409540 , Reply# 15   5/17/2019 at 14:50 (1,804 days old) by dandagreer (Nashville, TN)   |   | |
Many thanks to Lesinutah for hooking me up with this lovely reproduction bag for my 511. I'm so thrilled! Sure, it's not original, but it sure is snazzy!
Post# 409551 , Reply# 16   5/17/2019 at 22:24 (1,804 days old) by Lesinutah (Utah)   |   | |
