Thread Number: 38383
Rainbow D4C SE motor reassembly after repair - doubt |
Post# 408509 , Reply# 1   4/23/2019 at 07:33 (1,823 days old) by bikerray (Middle Earth)   |   | |
Did you replace all 3 bearings in the motor and fan housing?
When you put the motor back together did you make sure that all the fans, washers and spacers were in the correct order? If you left all the fan assembly in the housing and just pulled the armature out, one of the washers could have slid out of place and in between the fan blades. Next question did you tighten the nut at the end of the spider to lock everything in place? |
