Thread Number: 38364
Old Dysons (DC01- DC07) Crack Fixes. The Best and Easiest way to Prevent Cracks Spreading |
Post# 408281   4/18/2019 at 15:20 (1,828 days old) by maxeley4103 (East Sussex, United Kingdom)   |   | |
This is a quick and simple method for old Dysons. As everyone knows the older Dysons (Especially the British made ones) fade and become exceptionally brittle. Even us careful collectors can end up with cracks and splits in the plastics. If these cracks spread to much you can end up with large pieces of plastic breaking off making for sharp and ugly edges.
So what do you need. You will need, Toothpics or Ends of matches (which ever is to hand) and some Epoxy Resin or Acrylic Cement (Something like Gorilla glue). The next part couldn’t be simpler. Mix the glue preferably do this outside or in a well ventilated room as most Epoxy trains come in two parts that need to be mixed in the correct ratio (FOLLOW PACKET INSTRUCTIONS). Using the end of your chosen spreading device apply a small blob of the glue around the crack and then spread it as evenly as you can along the crack going about 3 millimetres either side of the crack to make sure it holds. Do this of both sides of the piece of plastic (if accessible) you will then need to dry for about 24 hours I hope this helps anyone worrying about severe damage to their old Dysons. This may not be the prettiest fix but it is easy and effective. |
Post# 408284 , Reply# 1   4/18/2019 at 21:33 (1,828 days old) by MadMan (Chicago, IL, USA)   |   | |
Good advice! But I do a little extra. I try to fill as much of the crack as possible with super glue, align both sides of the crack and press it together for 60 seconds. Allow that to cure for a day. Then rough up the back side (the not-visible side) with some ~150 grit sand paper. Then I proceed as above. Has worked well whenever I've done it. Real strong repair.
Post# 408285 , Reply# 2   4/18/2019 at 22:08 (1,828 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Post# 408358 , Reply# 3   4/20/2019 at 12:14 (1,826 days old) by crazykirbydude (Lexington, KY)   |   | |
Post# 408365 , Reply# 4   4/20/2019 at 13:03 (1,826 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Post# 408367 , Reply# 5   4/20/2019 at 13:55 (1,826 days old) by crazykirbydude (Lexington, KY)   |   | |
Post# 408396 , Reply# 6   4/21/2019 at 11:20 (1,825 days old) by Lesinutah (Utah)   |   | |
There is a few plastics with alot higher resistance than plastic. I agree the plastic Dyson uses is brittle as heck. I wouldn't call them junk alot of plastic vacs and they made best plastic crap. If they could have woven some fiberglass or something in plastic would have helped immensely. It is what it is.
Les |
Post# 408433 , Reply# 7   4/22/2019 at 09:59 (1,824 days old) by panasonicvac (Northern Utah)   |   | |
