Thread Number: 38329
Hoover 425 Questions |
Post# 407860 , Reply# 1   4/10/2019 at 07:04 (1,814 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 407862 , Reply# 2   4/10/2019 at 08:11 (1,814 days old) by bikerray (Middle Earth)   |   | |
The pulley is the correct one for the flat belt.
To get the agitator (brush roll) out 1. take off the bottom plate 2. take the belt off the pulley 3. lift the belt guard (the thing in the center) 4. Raise the lugs at each end toward the front of the machine. 5. the agitator should just lift out. If the lugs are stuck you might need to take a screwdrive and GENTLY pry up the lugs. It could be held in place by rust or string on the end of the agitator pushing outward on the clamping levers (the lugs). |
