Thread Number: 38295
One disgusting Royal |
Post# 407560 , Reply# 1   4/3/2019 at 20:12 (1,846 days old) by 97widerider (Indiana)   |   | |
Well it’s as good as it’s going to get. I need a new nozzle gasket but I believe they can still be found. I can’t seem to get the fan shaft off. Clockwise is off right? It takes a lot to turn it but not coming off. |
Post# 407561 , Reply# 2   4/3/2019 at 20:25 (1,846 days old) by Lesinutah (Utah)   |   | |
The motor housing encases everything and that was outside the housing. I recently got a 3c with a hole in motor housing. The carbon brushes we're down to almost the springs. The date stamp on the motor was 1960. I'm guessing it was opened before.
I'm going to show it's interior of motor housing. The coil had ground wires clamped on carbon brush housing. I had to undo two screws holding coil in. Fish through black shiz find clamps and disconnect all wires. I've seen it all as you will see that nobody maintains vacuums. I wouldn't be surprised someone chopped up a body and sucked up body parts into shakeout bag including emtor full and into fan coming out opening. It's like people drop into sinkhole tie to back of pick up pull out air dry and sale it. Anyways here is my latest cluster of what the. The second picture is wiring field coil Everything. The motor removed provided only opening. It's all pretty now but good grief. Les |
Post# 407562 , Reply# 3   4/3/2019 at 20:35 (1,846 days old) by Lesinutah (Utah)   |   | |
Post# 407604 , Reply# 5   4/4/2019 at 13:48 (1,846 days old) by Lesinutah (Utah)   |   | |
You dish washer isn't copesetic with most vacuum parts. I use barkeeper's friend and soak for a minute scrub everything with green scrub pad. I have an electric power washer. I've used once. It works amazing. I just don't like freezing water getting soakdd when it is freezing outside. I will use more
Power washing then straight to buffer makes it beautiful the quickest. Les |
Post# 407605 , Reply# 6   4/4/2019 at 14:22 (1,845 days old) by 97widerider (Indiana)   |   | |
Oh I know, just joking. However, I am going to soak the parts again in a laundry tub of hot water and Dawn dish shop. Any tips on how to get the fan shaft off? Seems to not want to turn much past 1/4 inch or so. |
Post# 407626 , Reply# 7   4/4/2019 at 21:14 (1,845 days old) by Lesinutah (Utah)   |   | |
If you look at pics the fan spindle is off. Use vice grips near base of fan as that section isn't most use part of fan. If you notice third picture is armature fan blades. You can do by hand hold in place and spindle of fan comes off counter clock wise. Once that's off fan just slides off.
So recap. Vice grips good vice grips. You clamp near base of fan lower shaft. Once vice grips are on. Use one hand to hold armature fan in place. Torque vice grips counter clock wise. I'd say 3/4 inch thread. It will spin off. Then with spindle off keep hand on armature fan pull up on fan twisting while pulling up and it slides up off freely. There may be a spacer on backside of the fan if no spacer then a washer. I took off mine a few weeks ago. Les |
Post# 407634 , Reply# 8   4/4/2019 at 22:22 (1,845 days old) by MadMan (Chicago, IL, USA)   |   | |
If you're going to use vise grips - not that you shouldn't - just remember that they chew up the shaft, and if you want to pull the shaft through the bearing (idk if it has ball or sleeve bearings, but doesn't matter) you'll have to file or grind the damaged bit of the shaft first. Basically smooth it out so that the shaft doesn't chew up the bearing on removal. In fact, you may have to do it anyway, to get the fan blade back on, but not sure about that.
Post# 407637 , Reply# 9   4/4/2019 at 22:45 (1,845 days old) by Lesinutah (Utah)   |   | |
Use a towel over vice grips to save scarring. If you don't be prepared with a 400 or higher grit sandpaper paper and spend 30 seconds to 2 mins filing down.
As for sleeve bearing the bearing are in hounding right above armature fan. So no bearing to deal with on this one. My vacuum is in great/ mint condition. The only issue is the headlight bumper and cord has. Nic in it. I may look to sell this but not sure. If anyone knows where to find royal trim let me know please. Les |
Post# 407661 , Reply# 11   4/5/2019 at 17:49 (1,844 days old) by Lesinutah (Utah)   |   | |
Post# 407671 , Reply# 12   4/5/2019 at 21:18 (1,844 days old) by MadMan (Chicago, IL, USA)   |   | |
