Thread Number: 38259
Help with Electrolux Model L |
Post# 407285 , Reply# 1   3/27/2019 at 23:05 (1,828 days old) by MadMan (Chicago, IL, USA)   |   | |
Assuming 11 and 12 are Line and Neutral from the cord going into the machine. They don't look polarized, so you can interchange 11 and 12. The same goes for 1 and 2.
What are 8, 9, 10 from? Is it some kind of safety switch or an indicator light? The main on/off switch appears to be 5, 6, 7 - is that correct? It's a little hard to tell which connections are blade connectors or 'eye' connectors. Can you get a brighter, closer picture of the end with the switch in it, so we can better see the connections on those switches? |
Post# 407291 , Reply# 2   3/28/2019 at 07:58 (1,827 days old) by bikerray (Middle Earth)   |   | |
11 and 12 go to the power outlet for the power nozzle. One lead would go to the switch and the other would go to the neutral junction.
1 and 2 from the motor one would go to the switch and the other would go to the neutral junction. 6 and 7 go to the hot side of the motor and power nozzle 9 and 10 go to the neutral side of the motor and power nozzle 8 would go to 5 to provide power to the switch |
Post# 407292 , Reply# 3   3/28/2019 at 08:29 (1,827 days old) by dysonman1 (the county)   |   | |
