Thread Number: 38005
vac of the day |
Post# 404991   2/2/2019 at 23:03 (1,880 days old) by chan55 (Green Bay, WI)   |   | |
I've often wondered how do you use that Kenmore tank on a cart. Would it tip over if you pulled on the hose? Did you have to keep pushing it around with the upright handle? |
Post# 404994 , Reply# 1   2/3/2019 at 00:32 (1,880 days old) by Lesinutah (Utah)   |   | |
Post# 405006 , Reply# 2   2/3/2019 at 08:21 (1,880 days old) by eurekaprince (Montreal, Canada)   |   | |
I don’t think the Kenmore Kart vacs were ever meant to be pulled by the hose while it is still on the cart. Either you position the cart in one spot before starting to vacuum (like the old GE Swivel Top or Airway “tower-style” vac), or you remove the cleaner from the cart and lie it down on its belly before starting to vacuum.
But I am sure that our friend KenKart would be able to answer this question better than me! :-D |
Post# 405092 , Reply# 5   2/5/2019 at 10:04 (1,878 days old) by dysonman1 (the county)   |   | |
According to the instruction manual that came with my Lakewood Green (side hose connection) KenKart, you could lay them on the ground so the handle touched the floor in front. You could pull the entire machine (still attached to the cart) around the room, although it would be very long and hard to maneuver like that.
