Thread Number: 37998
Filter Queen motor issue |
Post# 404926 , Reply# 1   2/1/2019 at 19:44 (1,903 days old) by compactc9guy (Bathurst NB)   |   | |
Post# 404929 , Reply# 2   2/1/2019 at 20:04 (1,903 days old) by Mister299 (Milwaukee, WI)   |   | |
What would carbon brush damage look like? Would it be chipped? Also are replacement brushes and bearings available? |
Post# 404931 , Reply# 3   2/1/2019 at 20:09 (1,903 days old) by compactc9guy (Bathurst NB)   |   | |
Yes part are available carbon brush would arch out and make marks on the AMATURE bearing would bea growling sound but ameteck motor should not fall apart so soon odd .Open her up and find out ,Best bet is replace the motor whit a Genuine Ameteck motor.BUT Filter Queen motors dont usually fall apart so suddenly id need more information from you when did it start any odd sound or smell?? its from 95 ive seen fitler queen from 75 run like a champ for years this is oddd
Post# 404958 , Reply# 5   2/2/2019 at 08:39 (1,902 days old) by dysonman1 (the county)   |   | |
Take the exhaust cap off, turn ON the machine, and look. Do you see lots of sparks (a small line of blue sparks is normal, but it's a straight line)? Can you smell an acrid smell of burning electrical? If not, the carbons are not the problem. Bearings for 23 years old, so they should be replaced. I'm shocked that a vac shop won't replace bearings. They must be independently wealthy. I replace bearings all the time. Bearings are very much available.
Post# 404963 , Reply# 7   2/2/2019 at 13:34 (1,902 days old) by Mister299 (Milwaukee, WI)   |   | |
I tried using it today and all of the sudden the motor slow down and noticed a burning smell so I turned it off right away. Time to bring the old Kirby Tradition up from the basement until I get this figured out! |
Post# 404982 , Reply# 8   2/2/2019 at 21:08 (1,902 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 405441 , Reply# 9   2/13/2019 at 18:04 (1,891 days old) by Mister299 (Milwaukee, WI)   |   | |
Well, I found a shop to look at the motor and it turns out it is a bad armature. They didn't have the parts to replace it. Does anyone have one that they want to part with? Or possibly a part# I can search for? |
Post# 405442 , Reply# 10   2/13/2019 at 18:15 (1,891 days old) by compactc9guy (Bathurst NB)   |   | |
Just research an amteck motor on ebay for tristar or filter queen will bolt right in your vacuum . Here you go single speed amteck vacuum ball bearing motor
CLICK HERE TO GO TO compactc9guy's LINK on eBay |
Post# 405460 , Reply# 12   2/13/2019 at 23:11 (1,891 days old) by MadMan (Chicago, IL, USA)   |   | |
