Thread Number: 37921
P.A.Geier(Royal) Model 83 |
Post# 404222   1/18/2019 at 09:21 (1,924 days old) by Ron6519 (East Williston, NY)   |   | |
I'm in the process of restoring this vacuum and need a source for the missing hand grip and beater bar. Thanks Ron |
Post# 404235 , Reply# 1   1/18/2019 at 15:00 (1,923 days old) by Lesinutah (Utah)   |   | |
Im pretty sure yours uses square end 14 inch.
I'll provide links to the ones I got for mine. They do fit and work. Les Link in URL is for handle. https://rover.ebay.com/rover/0/0/0QUESTI... I'm adding pics of listing. If I remember if either one is make offer do it for $10 less on brush roll. CLICK HERE TO GO TO Lesinutah's LINK on eBay |
Post# 404238 , Reply# 2   1/18/2019 at 15:07 (1,923 days old) by Lesinutah (Utah)   |   | |
Is the fan okay on the vacuum. Ben kindly found one to fit mine and I looked everywhere.
I also used led lights. I added pics. The second pic is a little longer. The first one took 3 weeks to get. Someone mentioned Lowe's carrying them. Sylvania 1650 is bulb number for regular light. If you need belts Kirby belts work. Hopefully your vacuum comes out of well. I have only had 2 days off in last 2 weeks. I polished but haven't found solder gun to finish mine. If you have any pics of wiring I'd appreciate it. Im mainly concerned about 2 carbon brush wires but any wiring pics would help. Les |
Post# 404293 , Reply# 5   1/19/2019 at 16:53 (1,922 days old) by Lesinutah (Utah)   |   | |
It says it's 14 but it we'll fit I know the good example is the Kirby brush rolls in 13in and the actual brush itself is 12 and 4 so they always added little bit of length but the 14th brush roll will fit because the two the vacuums that I have it say it fits the 13-inch with brushroll and major it's the same length that you mentioned but it will fit.
