Thread Number: 37902
What bulb does a Convertible take? |
Post# 404020 , Reply# 1   1/13/2019 at 15:15 (1,922 days old) by repairman (Woodridge, IL)   |   | |
Yes, it is a bayonet base. It's a 120V 15W watt bulb. I know Menards sells them under the Westinghouse brand. |
Post# 404024 , Reply# 2   1/13/2019 at 15:32 (1,922 days old) by weltron (Michigan)   |   | |
I'll look on their website, but the bayonet base that they were selling was not the circular base that I have, it was more of an oval base. |
Post# 404028 , Reply# 3   1/13/2019 at 16:35 (1,922 days old) by Lesinutah (Utah)   |   | |
Ba15d dual bayonet dual polarity.
That is the bulb you want to look for I believe Sylvania 1650. Led it varies I could give you a link I have went through numerous led bulbs I found good I also found garbage. The Kirby vacuums 505-classic 1, every royal that has alight new or old, eureka and sanitairre from 1970s to present take the same bulb, my riccar 8650 took same bulb new if they don't have cluster led lights they will take the bulb. Since almost every single vacuum takes them. I found the best brands. But 1650 Sylvania any auto parts store has them. Les |
Post# 404031 , Reply# 4   1/13/2019 at 17:12 (1,922 days old) by weltron (Michigan)   |   | |
Could you please post links to the good LED's you've had experience with? I'd be interested in putting an LED in it. |
Post# 404039 , Reply# 5   1/13/2019 at 20:04 (1,922 days old) by Lesinutah (Utah)   |   | |
This the bulbs are a little longer but there best I have bought.
https://rover.ebay.com/rover/0/0/0QUESTI... This one I just received these there average length it took almost 3 weeks to get but 10 bulbs for $18 is best bulb for price by far. The selection of white bulb and everything I ordered. They both Re really good it depends if you want to wait. With led never twist the top silicone twist and the bottom only insert only touching metal and when taking out. These are sturdier than most but the light source is a silicone top not glass like standard bulbs. You won't go back Les
Post# 404053 , Reply# 6   1/14/2019 at 02:08 (1,922 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 404063 , Reply# 7   1/14/2019 at 10:34 (1,922 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 404068 , Reply# 8   1/14/2019 at 12:53 (1,921 days old) by Lesinutah (Utah)   |   | |
Post# 404074 , Reply# 9   1/14/2019 at 15:07 (1,921 days old) by rivstg1 (colorado springs)   |   | |
Post# 404083 , Reply# 11   1/14/2019 at 18:19 (1,921 days old) by rivstg1 (colorado springs)   |   | |
I found that if the machine in question uses dual filaments (dual lead ends in the old bulbs) and were round, the replacements ( non original) were oval and worked the same
https://www.ebay.com/itm/232680388320QUE... |
Post# 404086 , Reply# 12   1/14/2019 at 19:14 (1,921 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 404096 , Reply# 13   1/14/2019 at 23:27 (1,921 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 404098 , Reply# 14   1/14/2019 at 23:51 (1,921 days old) by Lesinutah (Utah)   |   | |
Post# 404389 , Reply# 16   1/21/2019 at 20:56 (1,914 days old) by Lesinutah (Utah)   |   | |
