Thread Number: 37874
Kirby Sanitronic D80 Motor Housing Disassembly |
Post# 403728 , Reply# 1   1/7/2019 at 20:31 (1,934 days old) by Lesinutah (Utah)   |   | |
Post# 403729 , Reply# 2   1/7/2019 at 20:38 (1,934 days old) by Lesinutah (Utah)   |   | |
While checking spring maybe check make sure carbon brushes are good.
The carbon brushes are in black housing. They have a silver clip holding them to housing. The plastic clear caps come off. Then there is a green wire and a black wire. The end of wires is a v clipped item you push those out the sides. I could tell you more but one at a time. Don't mess with electrical power switch. There touchy little suckers. Good luck. Les |
Post# 403734 , Reply# 3   1/7/2019 at 22:22 (1,934 days old) by Lesinutah (Utah)   |   | |
Post# 403735 , Reply# 4   1/7/2019 at 22:37 (1,934 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Kevin,
Welcome to VacuumLand! Here is my Dual Sanitronic 80. And if you ever run into a problem with getting the motor to run again following re-assembly, please check out this thread started by Bill (vaclab): www.vacuumland.org/cgi-bi... ~Ben
