Thread Number: 37717
Royal 882T Estate Sale Find |
Post# 402198 , Reply# 1   12/8/2018 at 17:09 (1,958 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Tim,
This 882T was built in April 1991 according to the serial number, which would mean it would take the square-ended brush roll assembly. And speaking of that, you will have to do quite a bit of looking around for one (part no. 2-059721-000 or 2-159273-000) as Royal/TTI hadn't made them for about a decade now. And also, a replacement belt for this model is part no. 1-044260-001. About oiling the rear bearing in the motor: yes, it is recommended to do so about each year for general household use (if used commercially, then oil more frequently). Use only medium-grade (SAE 30) oil (don't use lightweight or sewing machine oil), and take care not to overfill the oil wick. ~Ben |
Post# 402209 , Reply# 3   12/8/2018 at 19:28 (1,958 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Tim, This post was last edited 12/08/2018 at 19:52 |
Post# 402376 , Reply# 4   12/11/2018 at 05:50 (1,955 days old) by timborow (Georgia)   |   | |
Would this model Royal ever had a brush roll with stiffeners? Could I use a brush with stiffeners? |
Post# 402382 , Reply# 5   12/11/2018 at 09:23 (1,955 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Tim,
In 1991, this model initially had the single-bristle brush roll (2-159273-000), but yes, you can change that to a double-bristle type with stiffeners. For this model, you can use part no. 2-088221-000, 2-188273-000 or 2-675227-000. ~Ben This post was last edited 12/11/2018 at 11:15 |
