Thread Number: 37716
Continuity |
Post# 402189   12/8/2018 at 15:02 (1,964 days old) by Lesinutah (Utah)   |   | |
Hey
I'm trying to figure out what wires go together on my old royal vacuum. I have a good multi meter. I know you place 2 wires on to check. I believe I know what setting. I'm just not sure what else. This is my a pic of my meter I believe it's on the right setting. If anyone could explain a little further would be greatly appreciated. Les
Post# 402203 , Reply# 2   12/8/2018 at 17:54 (1,964 days old) by Lesinutah (Utah)   |   | |
Post# 402204 , Reply# 3   12/8/2018 at 18:08 (1,964 days old) by compactc9guy (Bathurst NB)   |   | |
Post# 402207 , Reply# 4   12/8/2018 at 19:04 (1,964 days old) by Lesinutah (Utah)   |   | |
Post# 402214 , Reply# 5   12/8/2018 at 23:25 (1,963 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
I've never used a multimeter, I'm sorry I can't be of help. As much as I know you have to have it set to a certain setting, oHm's I think, and then test positive and negative terminals, or something like that. Basically whichever direction current flows. That is my assumption.
Madman might have a lot more experience than I do. That looks like a really complex model there, I've only ever seen something like that used by the furnace repairman, the ones I've seen in the store ads are bare bones basic ones with just a few settings. |
Post# 402219 , Reply# 6   12/9/2018 at 03:45 (1,963 days old) by MadMan (Chicago, IL, USA)   |   | |
All multimeters function a bit differently. Some will make a noise when you have a good connection, or perhaps different noises for varyingly poorer connections. Good continuity is generally acceptable at anything less than 1 ohm. Some things, like car diagnostic instructions, will sometimes say that 2 ohms or less is acceptable. The lower the number, the less resistance, the better the connection. Higher resistance = less connectivity. (And just as an aside, remember that a higher resistance passes less current. Which can be confusing sometimes.)
It appears your meter is in the correct setting, and the test leads are in the right places, simply touch the test leads together to simulate a continuous circuit (the test leads themselves), the meter should read something like 0.1 or 0.2. Whenever I take my meter out, I do this test just to make sure the instrument and the test leads are working well. Your meter apparently says '0.L' when there is NO connection whatsoever. Also, note on the right side of the display it says 'MΩ', which means megaohms, or million ohms. It will probably also have 'KΩ' for kilo ohms, or thousand ohms. It's important to pay attention to that part of the screen, because you may be reading 0.6, which looks like a good continuous circuit, until you realize it's in kilo ohms, and that's actually a pretty poor connection. |
Post# 402220 , Reply# 7   12/9/2018 at 03:54 (1,963 days old) by MadMan (Chicago, IL, USA)   |   | |
Also, yes, if you are touching one lead to one wire and the other lead to another wire, and the meter reads less than 1 ohm, those two wires are connected... somehow.
Also also, it doesn't matter which way around you have the test leads attached to what you're checking, because continuity goes both ways... unless there's a diode, but I doubt you'll run into one. |
Post# 402248 , Reply# 8   12/9/2018 at 20:45 (1,962 days old) by Lesinutah (Utah)   |   | |
