Thread Number: 37492
Kirby G4 No reverse |
Post# 399956 , Reply# 1   10/23/2018 at 13:08 (2,010 days old) by dysonman1 (the county)   |   | |
When you take off the top cover, one of two things will be wrong. Either the handle pivot has come out of the transmission fork, or the handle pivot is no longer in the middle position. The two big black screws should be removed and the handle pivot set into the transmission fork. Make sure the two screws are tightened in the middle of the screw openings so it moves the exact amount of distance on forward and back stroke.
Post# 399958 , Reply# 2   10/23/2018 at 14:18 (2,010 days old) by scudo (uk)   |   | |
Thanks for your quick response. |
Post# 400034 , Reply# 4   10/25/2018 at 17:41 (2,008 days old) by scudo (uk)   |   | |
Was going to edit to update but not allowed, anyhow here is the Kirby after a couple of days cleaning, now going to start polishing the casings. |
Post# 400044 , Reply# 5   10/25/2018 at 22:00 (2,008 days old) by human (Pines of Carolina)   |   | |
