Thread Number: 37363
Tradition wiring |
Post# 398661   9/23/2018 at 21:03 (2,038 days old) by Lesinutah (Utah)   |   | |
I found this in a thread posted by Ben. I'm trying to wire bypassing switch. Please I know safety switch put there for a reason I'm bypassing for a reason. I want to use hose from classic that has safety switch d80 has. The only option is to bypass switch. I also want to use rug rennovator on it.
The diagram looks like the safety switch a switch for field coil. I get black is power. The headlight I think orange is power wire but on second diagram it looks to be white. I believe top diagram is for my vacuum. So I'm going with orange. Red from switch is third hot wire. I'd have to splice and bunny tail I think is what it's called. I add wire to orande run too black or hot wire side of switch. There is 2 whites and yellow from switch all go to neutral or w side of switch. The 2 green are ground and ground accordingly. It's weird seeing 8 wire one speed switch. Especially headlight and usually 2nd speed run all by field coil. Insight would be appreciated. I solder flux and headshrink all spliced wires so no potential for wires arcing out. Les
Post# 398662 , Reply# 1   9/23/2018 at 21:11 (2,038 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 398670 , Reply# 2   9/23/2018 at 22:41 (2,038 days old) by Lesinutah (Utah)   |   | |
Post# 398673 , Reply# 3   9/23/2018 at 23:29 (2,038 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 398674 , Reply# 4   9/23/2018 at 23:39 (2,038 days old) by Lesinutah (Utah)   |   | |
Post# 398692 , Reply# 5   9/24/2018 at 10:51 (2,037 days old) by Lesinutah (Utah)   |   | |
Post# 398693 , Reply# 6   9/24/2018 at 10:55 (2,037 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 398721 , Reply# 7   9/24/2018 at 22:11 (2,037 days old) by Lesinutah (Utah)   |   | |
