Thread Number: 36640
Kirby G4 Armature |
Post# 392222 , Reply# 1   5/22/2018 at 23:39 (2,136 days old) by Lesinutah (Utah)   |   | |
Post# 392223 , Reply# 2   5/23/2018 at 00:43 (2,136 days old) by tolivac (Greenville,NC)   |   | |
Looiks pretty normal. |
Post# 392249 , Reply# 3   5/23/2018 at 11:44 (2,136 days old) by Repairman (Woodridge, IL)   |   | |
I am aware of where the brushes hit the commutator. I just want to know if the small line in the middle of the middle mark is a sign of death as seen in the third picture. |
Post# 392252 , Reply# 4   5/23/2018 at 12:56 (2,135 days old) by broomvac (N/A)   |   | |
Looks great to me—and yes, I see the ring you speak of. If that were my vacuum, I would not be concerned. In fact, it looks cleaner than a number of (also good) armatures I have come across.
But, just to play the devil’s advocate, let’s say the armature is actually damaged. What’s the worst that could happen? One day it would just quit working and at that point you would have to get a new armature anyways. Using it until it fails shouldn’t cause any collateral damage. You would simply get a few more miles out of the original armature. Nevertheless, I don’t think you will ever see that armature fail and you will able to save yourself some cash by not getting a new one. :) |
Post# 392261 , Reply# 5   5/23/2018 at 15:52 (2,135 days old) by dysonman1 (the county)   |   | |
Post# 392265 , Reply# 6   5/23/2018 at 16:13 (2,135 days old) by panasonicvac (Northern Utah)   |   | |
Post# 392304 , Reply# 7   5/24/2018 at 23:43 (2,134 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 392586 , Reply# 8   5/31/2018 at 15:41 (2,127 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
The ring you describe is actually just the copper being stained from years of carbon buildup, that is normal. There will be more wear in the middle because that is where the brushes are pressed against the armature at their strongest. Both the armature and brushes still look new, like its been barely broken in.
Some arcing is normal, it's where it becomes a huge arc that envelops the motor and starts melting wires that can be an issue. This is what would be an example of a bad arcing and a bad armature, where it is actually chasing the armature all the way around and is throwing sparks out of the fan housing: Your armature can use a little bit of polishing up if you want, I followed this video: |
Post# 392646 , Reply# 10   6/1/2018 at 17:03 (2,126 days old) by bikerray (Middle Earth)   |   | |
Post# 404975 , Reply# 11   2/2/2019 at 17:56 (1,880 days old) by anthony (leeds uk)   |   | |
Post# 404984 , Reply# 12   2/2/2019 at 21:23 (1,880 days old) by MadMan (Chicago, IL, USA)   |   | |
To each their own, I suppose.
I think sometimes people hear 'sand paper' and immediately think it's 80 grit. 800 grit, on the other hand, is more like emery cloth. It's leaving 'sanding' territory and heading into 'polishing.' Often if I say to someone to use sandpaper to clean electrical contacts they'll try to educate me about how bad that is, and that I should use a contact burnishing tool instead... which is literally just a fancy strip of 1000 grit sandpaper. It's all a matter of semantics, I suppose. Anyhow, me personally, I wouldn't use sand paper unless the commutator was really bad. For a little freshening up, a ScotchBrite pad will do just fine. And yeah, it's technically abrasive too. If you wanted it really abnormally perfect, I suppose you could sand with increasingly higher grits until you hit 3000, but I believe it's wholly unnecessary. |
Post# 405166 , Reply# 13   2/6/2019 at 21:59 (1,876 days old) by vaclab (Pickerington, Ohio)   |   | |
are what I've been using for years to clean/polish my commutators. Cleans the carbon build up off and trues up the surface so that the carbon brushes spark less and make a better contact which gives a higher rotational speed.
Anthony, I don't understand your comment at all. Want proof? Check out my latest Kirby G3 reassembly video around the 15 minute mark to witness commutator polishing. Listen to the motor speed rise and the wind down smooth out. |
