Thread Number: 33490
Need help to change Kirby Sanitrnic VII bearings. |
Post# 364859 , Reply# 2   1/7/2017 at 19:34 (2,664 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 364866 , Reply# 3   1/8/2017 at 00:23 (2,664 days old) by chicagomike (Plover, WI)   |   | |
Good job Ben!! The videos will definitely help - and if they do not help Nali look at some of my other videos as they will show how to take the S7 apart, the videos I have are not the specifically the S7 model but generally they are all the same. Some day I will make a video taking apart and re-assembling every Kirby model there is...
P.S., heat does not hurt a darn thing especially since you are going to install new bearings. And you might need heat to get some things apart. |
Post# 364867 , Reply# 4   1/8/2017 at 00:27 (2,664 days old) by chicagomike (Plover, WI)   |   | |
P.S., the only place you really need a puller is for the rear bearing. And honestly, if you don't have a tool that fits the small bearing to remove it, cut it off as you are installing a new bearing anyways so who cares if you destroy the rear bearing - just be careful not to damage the armature shaft.
Post# 364868 , Reply# 5   1/8/2017 at 01:16 (2,663 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 364907 , Reply# 8   1/8/2017 at 23:27 (2,663 days old) by Repairman (Woodridge, IL)   |   | |
The hole on the armature is the one I was telling you about before because I assumed you were going to unscrew it by hand. |
Post# 364909 , Reply# 9   1/9/2017 at 02:21 (2,662 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 364990 , Reply# 10   1/11/2017 at 01:44 (2,660 days old) by nali (Montréal)   |   | |
My B&D seems to be from 1958. I also have a Lesto / Bosch jigsaw from the same period, which is brand new and unused because the first owner has broken the mechanism to fix the blade as soon as he got it out of the box :)
Post# 364991 , Reply# 11   1/11/2017 at 05:31 (2,660 days old) by tolivac (Greenville,NC)   |   | |
Nice Bosch jigsaw-remember one of these at the tool repair place.These were better made than the current models.Worth fixing up! |
Post# 365054 , Reply# 12   1/12/2017 at 01:26 (2,659 days old) by nali (Montréal)   |   | |
Well built yes. All metal inside, and roller bearings. No cheap plastic. |
