Thread Number: 33234
Electrolux Automatic Model G trouble |
Post# 362777 , Reply# 1   11/25/2016 at 14:30 (2,706 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 362812 , Reply# 2   11/26/2016 at 19:32 (2,705 days old) by bikerray (Middle Earth)   |   | |
1. The brass tube on the side of the tube that the hose plugs into should have a small opening about the size of a thin wire (like the wire in a twist tie).
2. Take the control valve out of the front of the Model G, unscrew the knob and check to see if the rubber O ring is seated in between two thin ridges of plastic. If the front piece of the plastic knob is broken and not holding the O ring in place the valve will leak from one chamber to another and the front of the G will open. |
Post# 362893 , Reply# 4   11/29/2016 at 14:12 (2,702 days old) by ronni (USA)   |   | |
I used the stripped twist tie in the brass nipple to remedy the same situation in my Model G. Since that didn't work for you, try blowing through the clear tubes to dislodge any blockages. |
Post# 362918 , Reply# 6   11/29/2016 at 23:28 (2,701 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 362924 , Reply# 7   11/30/2016 at 08:26 (2,701 days old) by mchmike (West palm beach fl)   |   | |
These are genuine crevice tools for a tan G and a turquoise G . If your using an aftermarket tool that is too small it may be chocking the air flow through the machine causing it to pop prematurely . Uhhumm on that last phrase.
Post# 362926 , Reply# 8   11/30/2016 at 09:40 (2,701 days old) by kirbyvertibles (Independence, KS)   |   | |
I was talking with an old retired elux friend of mine about this and he said maybe its your bag. He said some of the plastic body models of the 90s would do this if cheap generic bags were used. Maybe this is the case with the old metal G.
Some of the generic bags are great but there are some that are terrible. Just a thought. |
Post# 362992 , Reply# 11   12/2/2016 at 09:53 (2,699 days old) by suckolux (Yuba City, CA)   |   | |
Post# 362994 , Reply# 12   12/2/2016 at 10:31 (2,699 days old) by mchmike (West palm beach fl)   |   | |
Those bags your using are from like the 70's . I would try some new ones they may rip on you and flood the motor with sand and dust. |
