Thread Number: 32315
Replace attachment connector/latch on Filter Queen Majestic 70th Anniversary? |
Post# 355327 , Reply# 2   7/4/2016 at 16:29 (2,824 days old) by Blackheart (North Dakota)   |   | |
Are replaceable. You can find them on ebay for around $10, it comes with the latch and the spring. They are pretty easy to install. you just use a flat head to remove the "pin" from the holes on one side, and remove. Once that's finished you set the spring in insert one of the pins into one side then using a flat head you pry the latch away from the side to make sure the other pin pops into place.
I've had to replace one of them on my 75th Anniversary FQ. |
