Thread Number: 31244
Eureka Handle Yoke Removal HELP :) Model G |
Post# 345637   2/27/2016 at 19:26 (2,973 days old) by chicagomike (Plover, WI)   |   | |
HI, can anyone please tell me how to remove the handle yoke, "Y" part of the lower handle, from the motor section of a Eureka Model G vacuum? There is not enough flex in the handle yoke to spread both sides apart and slide over the knubs they click into.
Post# 345781 , Reply# 1   2/29/2016 at 10:53 (2,971 days old) by chicagomike (Plover, WI)   |   | |
Post# 345783 , Reply# 2   2/29/2016 at 11:28 (2,971 days old) by electrolux137 (Los Angeles)   |   | |
Post# 345945 , Reply# 4   3/1/2016 at 15:06 (2,970 days old) by chicagomike (Plover, WI)   |   | |
WELL I FIGURED it out how to remove the handle yoke, the entire motor assembly needs to me reomved, then you get access to 2 nuts that when removed allows the yoke to simply fall off... The only part that sucks is putting the wiring back inside as there are 2 switches, along with everything else.. BUT the handle yoke is removed!
Post# 346118 , Reply# 5   3/3/2016 at 08:03 (2,968 days old) by cuffs054 (monticello, ga)   |   | |
Is that the power switch mounted on the bottom? |
Post# 347175 , Reply# 6   3/11/2016 at 18:04 (2,960 days old) by chicagomike (Plover, WI)   |   | |
