Thread Number: 30683
Samsung Quiet Storm Canister Vacuum Bags |
Post# 339606   12/19/2015 at 05:51 (3,042 days old) by fantomfan57 (Central Texas)   |   | |
Hi all, I just found one of these that uses VP-90 bags that are kinda scarce /pricey. Was wondering if I could substitute bags from another brand vacuum? I will drag down my 3 tubs of bags and experiment. |
Post# 339614 , Reply# 1   12/19/2015 at 12:26 (3,042 days old) by fantomlightning (Ohio)   |   | |
That's the machine I'm thinking of, you should be able to use Bissell Digipro bags in it. If they're really any cheaper I'm not to sure with how relatively uncommon the machine is. |
Post# 339636 , Reply# 2   12/19/2015 at 20:58 (3,042 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
That particular Samsung vacuum was VERY popular here in Canada, & bags should be easily obtained from most any vac shop. The Bissell Digipro bags look like they would work fine as well. Both the VP-90 bags & Digipro bags are available on Amazon.com & looks to be fairly common on online vendors.
If you wanted to substitute bags, though, you could try a Panasonic C-18 bag, JohnnyVac Hydrogen bag, or Miele FJM bag. The hole on the bag collar looks nearly the same, as well as being pretty close to the same size. You would have to remove the bag holder in the canister & mount the bag DIRECTLY on the tube on the bag door, & possibly wrap the tube with a little clear parcelling tape that can be obtained at most dollar stores, to make the bag fit a little more snug on the tube. Both these bags are made of HEPA Cloth, whereas the Samsung & Bissell bags aren't, so it might be worthwhile if you want the better filtration, & unfortunately Samsung didn't use the best quality HEPA filters on the exhaust of these canisters. Rob |
