Thread Number: 30263
Will Kirby attachments fit a Shark Navigator Lift-Away? |
Post# 335899 , Reply# 1   10/19/2015 at 15:22 (3,109 days old) by CharlesKirby66 (Manteca, CA)   |   | |
Although I don't know 100% for sure. The Kirby attachments are twist-pressure mounted. The Shark hose doesn't have that twist-pressure pattern on its end, and it has a plastic tab which protrudes and helps you align the Shark hard floor nozzle. Methinks this would get in the way of fully inserting the hose into the attachments. Again, I don't know 100% for sure, because once I switched from Shark to Kirby, I never looked back for a second!
But hey, good luck! |
Post# 335900 , Reply# 2   10/19/2015 at 15:28 (3,109 days old) by HVRVACLVR (Altoona PA)   |   | |
Post# 335997 , Reply# 3   10/21/2015 at 13:08 (3,107 days old) by mark40511 (Lexington, KY)   |   | |
At least with the Professional lift away -
Mine came with a car detail kit which had a small adapter that I use if I want to use other vacuums attachments. I don't use attachments much on my shark I just use it as upright to vacuum carpets, but every now and then I end up using the dusting brush and crevice tool, but the dusting brush that came with the shark is a total joke, so I use a better dusting brush. |
