Thread Number: 19956
Royal 880- hot rod it, yes or no? |
Post# 223399   3/13/2013 at 15:10 (4,060 days old) by stricklybojack (Southern California)   |   | |
I am mid spa-session with this Royal i won at auction from the Tucson Arizona Goodwill. As a testimony to the light weight nature of these Royals shipping was reasonable at $15.
Anyhow, whilst it is disassembled should i change out the fairly pristine fan and/or the 3 amp motor? And if so, what is a good parts source for the upgrades? In the pic the nozzle has been cleaned but the rest only partially. This has a lot of desert dust on it but no grime to speak of...other than the bag which now looks like new, but required over an hour of hand washing to sparckle as it should. SER NO. 67J C 110237 |
Post# 223429 , Reply# 1   3/13/2013 at 19:44 (4,060 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Serial # means this unit was built in September 1976.
As to changing the internals to something stronger: such parts/assemblies will likely need to be procured from later Royals of the '80s and early '90s. The Royal service manual from TTI says these upgrades can be used: TO 5.4 AMP OR 6 AMP MOTOR Armature: 1680001000 (NLA) Field: 1618002000 Motor plate assembly: 2088007500 (NLA) Fan: 1608005000 Shaft: 1380261000 TO 7 AMP MOTOR Armature: 1780001000 Field: 1780002000 Motor plate assembly: 2088007500 (NLA) Fan: 1608005000 Shaft: 1380261000 NLA = no longer available; procure from donor (March 1995 or older) Royals containing said parts. ~Ben |
Post# 223450 , Reply# 2   3/13/2013 at 22:21 (4,059 days old) by djtaylor (Salt Lake City, Utah)   |   | |
Post# 223466 , Reply# 3   3/14/2013 at 01:48 (4,059 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Justin,
You could try doing that but the replacement 9-blade fan will be a different part # than that used on 1990 and later machines that already have it. 9-blade impeller fans used in replacement for pre-1990 machines are all of a threaded design: #1608004000 = 1/4" (0.25mm) shaft hole #1620004000 = 5/16" (0.3125mm) shaft hole The original 6-blade impeller fan, #1053004000, had a 7/32" (0.2188mm) shaft hole. Again: the 9-blade fan used on original production of 1990 and later Royal uprights is a slip-on design, but the 9-blade impeller fans used in replacement are threaded. ~Ben |
