Thread Number: 9620
Rainbow question???? SC vacuumguy |
Post# 105379 , Reply# 1   8/7/2010 at 21:03 (5,003 days old) by scvacuumguy (SC)   |   | |
Sorry for the delay in reply- I didn't see this pop up. There are three options, no four to repair this: 1) soak the brass nut in a lot of WD and hope like H3ll it will loosen up 2) Jam a flathead screwdriver in the spider, and try to remove the brass nut that way. A pair of vice grips on the back end of the motor shaft also work. 3) Remove the motor, remove carbons, remove top cooling fan, remove carbon housing and coil assembly. Grip the armature with a rag and try turning the brass nut off with a pair of vice grips. 4) Grind the brass nut off on a bench grinder being VERY careful not to damage the armature shaft (I do NOT recommend this one unless you know what you are doing!!!!) |
Post# 105441 , Reply# 2   8/8/2010 at 18:42 (5,002 days old) by kirbykid63 (Wilmington Delaware)   |   | |
The last one I took apart the nut came off without any drama. The nut looks good I will try your suggestions wish me luck . Richard new2youvacuums |
Post# 105448 , Reply# 3   8/8/2010 at 21:49 (5,002 days old) by scvacuumguy (SC)   |   | |
Post# 105498 , Reply# 4   8/9/2010 at 18:26 (5,001 days old) by kirbykid63 (Wilmington Delaware)   |   | |
The nut came off removed the clips placed a drop of oil in the lower bearing and got it all back together.Do I still want a D4-SE? what a job. |
Post# 105504 , Reply# 5   8/9/2010 at 19:17 (5,001 days old) by scvacuumguy (SC)   |   | |
