Thread Number: 9342
Kirby Heritage II Question |
Post# 102809 , Reply# 1   7/7/2010 at 20:41 (5,039 days old) by briankirbyclass (Eudora Kansas)   |   | |
It should clean as well, if not better than a D 80. Make sure the brush roll is a 4 row brush roll,(4 rows clean better than 2, and also makes the Kirby easier to push) make sure there is a new belt installed,or at least one that is not worn down, and make sure that the brush roll is adjusted correctly. The bristles of the brush roll should protrude slightly from the bottom of the rug plate. Also make sure that the rug nozzle itself is adjusted correctly for your carpet by turning on the Kirby with the rug nozzle in the highest position (foot pedal all the way down), then step on the adjustment pedal one click at a time until you hear a change in tone of the Kirby motor. This indicates the correct setting. If the Kirby is hard to push at this setting, go back up one. If the suction is broken when you push and pull the Kirby at this setting go down one notch. Also make sure the Kirby bag is empty, or at least not jammed up. |
Post# 102884 , Reply# 3   7/8/2010 at 17:45 (5,038 days old) by streakers (Columbus Ohio)   |   | |
Post# 103051 , Reply# 4   7/11/2010 at 09:26 (5,035 days old) by swiveltop (Galveston, TX)   |   | |
Noise does't always mean more power or suction, I have a small head Heritage two and just got a dual 80 Friday, as soon as I clean the bag I'll bring it upstairs, One good test would be to put the hose on both and compare suction. |
Post# 103066 , Reply# 5   7/11/2010 at 13:36 (5,035 days old) by eurekastar (Amarillo, Texas)   |   | |
The Legend II that I finished rebuilding is essentially the same vacuum as yours. Though I've never used a D80, I can say that my Legend II has plenty of power and vacuums very well. I wonder if you're noticing the difference between an internal bag system on the Heritage II and the shake out bag on your D80. Would the newer internal bag systems not breathe as freely and therefore give the impression of reduced power? I really don't know.
