Thread Number: 8923
Questions for Electrolux experts |
Post# 98807 , Reply# 2   5/22/2010 at 01:54 (5,085 days old) by gmerkt (Edmonds WA)   |   | |
Next, the power nozzle. Note the approximate 12 to 14 inches of cord extending beyond the inlet tube -- am I missing a short length of tube, or does the outlet end of the hose connect onto what I've got? |
Post# 98828 , Reply# 5   5/22/2010 at 09:23 (5,084 days old) by kirbykid63 (Wilmington Delaware)   |   | |
Get your hose from hesco.their prices are very good for vacuum parts. |
Post# 98835 , Reply# 6   5/22/2010 at 11:30 (5,084 days old) by eurekastar (Amarillo, Texas)   |   | |
One of these days, I'd like to get a 1205. But it seems like every one I find is in really bad shape cosmetically. Every Lux that I own came to me in very good shape. Most were used quite heavily too. But for some reason, the 1205 is the one model that just didn't seem to age well. Also, here's a link for the kind of hose you can purchase. CLICK HERE TO GO TO eurekastar's LINK on eBay |
Post# 98841 , Reply# 8   5/22/2010 at 12:13 (5,084 days old) by compactelectra (Palm Springs)   |   | |
For these machines from Aerus - successor to Electrolux. I have even been able to get these hoses with the machine end pigtail for the G and earlier machines. Very good quality, but not cheap. The last one I purchased was about $90. But as I said, excellent quality and the real lux pistol grip. Here is a nice assortment and price range. And a real Lux hose with my 1205. For some reason, while I find the machine beautiful, I don't find the performance that good since I compare it with the Super J I bought new which had a larger motor.
CLICK HERE TO GO TO compactelectra's LINK |
Post# 98868 , Reply# 9   5/22/2010 at 19:14 (5,084 days old) by kirbykid63 (Wilmington Delaware)   |   | |
I like these because the motors are so easy to rebuild,the bearings and brushes are still available and they are easy to disassemble. |
Post# 98869 , Reply# 10   5/22/2010 at 19:19 (5,084 days old) by kirbykid63 (Wilmington Delaware)   |   | |
I find the front caster wheel is most likely worn on these metal body Electrolux's but you can buy the same size caster at home depot. makes a big difference on how the machine moves. |
Post# 98873 , Reply# 11   5/22/2010 at 20:16 (5,084 days old) by compactelectra (Palm Springs)   |   | |
Post# 98874 , Reply# 12   5/22/2010 at 20:17 (5,084 days old) by compactelectra (Palm Springs)   |   | |
Post# 98875 , Reply# 13   5/22/2010 at 20:19 (5,084 days old) by compactelectra (Palm Springs)   |   | |
Post# 98896 , Reply# 14   5/22/2010 at 23:54 (5,084 days old) by gmerkt (Edmonds WA)   |   | |
Many thanks for the info. |
Post# 99066 , Reply# 15   5/25/2010 at 10:38 (5,081 days old) by collector2 (Moose Jaw, Sk)   |   | |
Hi Gary: Just to explain the handgrip. The original power hose for that 1205 has a metal handgrip thats basically the same as what you see on all the earlier, non power, hoses. The electrical connection was at the place where the hose met the hangrip hence the length of cord at the end of the wand. The plastic style handgrip shown in the pictures above was made to go with the wands that have the cord end flush with the top of the wand to mate directly into the handgrip. Doug |
Post# 99109 , Reply# 16   5/25/2010 at 19:44 (5,081 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
An original 1205 electric hose with metal hand-grip & suction relief valve. Integrated blade contacts at the connector end. The first electric hose had an extended pigtail instead of the blades for connection to Model Gs. Electrolux offered the electric hose with any combination of connection options so that owners of previous machines supplied with, or retrofitted with a PN power socket, could add an older or the new Power nozzle alone. The ultimate brag was to have a brand spankin' new 1205 with the new self-connecting hose and polished aluminum/chrome PN designed for it. This adaptability is the main reason the hose pigtail seems overly long. It also kept the cord looped away from the freely swiveling hand-grip so as not to entangle Milady's manicured fingers. The plastic hand-grip & redesigned wand with integrated & enshrouded pn connections solved this last inconvenience, although the thicker handle did limit where Milady could comfortably grip the hose to steer the pn over, under, around and between. Besides having to include freshly engineered electric slip-tings and and contact fingers - to retain the swivel action hose - the new plastic handle shape also introduced an abrupt 45 degree corner into the air path which was great for catching large clogging objects like toy Cowboys, Injuns and Soldiers, toy blocks, teething rings, Crock marbles, escaped hamsters on the loose, wood chips & twigs, pet turtles out for a slow race, and such for easy removal...where the gently curved one-piece metal handle allowed some snarly items to pass into the coiled hose where they could get snagged and a broom handle would have to be engaged to dislodge them. Electrolux introduced its first power nozzle on the late 1958 Model F and the plug went into an outlet on the side of the front wheel assembly. It all seems so obvious to our eyes now but at the time it was one clever invention and innovation rapidly superseded by the next great development of that idea...to reliably energize a powernozzle from the vacuum cleaner point of origin rather than a separate long corded plug-in accessory...but with backward compatibility always in mind. Other companies burned the midnight oil coming up with their own variation on the Power Nozzle concept without infringing on Electrolux's patents...with interesting results and some unfortunate incidents. Next out of the gate was Lewyt with their gear driven brushroll powered by 120 VAC through a long cord back to the machine which plugged a regular bladed AC plug into a supplied socket. Their mistake was in getting too clever utilizing low voltage to run their Electronic PN. As Lewyt's disaster unfolded, no vacuum company wanted to risk ending up with their ass sued into oblivion like Lewyt. Hoover quickly abandoned further development of their 1959/60 electric hose Constellation model 87 under the very real possibility it would be compared unfavorably to the Lewyt Electronic. The next Hoover to feature a handle mounted on/off switch was the early 1970s S3007 Celebrity with the pneumatic pump system running through the hose, gasketed at the vacuum connection, continuing the pneumatic hose into the lower vacuum body, spiraling around the hinge, ending up at a plungered micro-switch in the top lid. Now that's over-the-top engineering. LOL So who made the first motor-driven Power Nozzle? I nominate the 1935 Air-Way Chief. just my rambling thoughts. Any errors are entirely my own speculations. Dave This is my ugly old couch's scratchy polyester upholstery fabric - I found a dated "Kroehler Manufacturing Co. Limited, Stratford Ontario" label under the cushions for 1969. It was gently used when I got it and it was the sheer length and low height that made me have to have it. Certainly not the colour. UGLY! No wonder I made a white canvas cover for the whole thing when I moved into the house in 1986. |
Post# 99136 , Reply# 17   5/26/2010 at 00:07 (5,081 days old) by briankirbyclass (Eudora Kansas)   |   | |
I always thought those PN sockets on those 1205 hoses were so cool because you could plug the PN into either side! And the special angle of the plug was cool too. Good ol Electrolux engineering! An Aunt had a 1205 with this same hose and PN,,and was using it one day in the late 1970s, with the PN attached when all of a sudden sparks came flying out of the hose,,just a little ways down from the handle. Sure enough there was a little black burned spot on the hose, about the size of a pencil eraser. She called the Electrolux man, and he sold her a new Golden J/Super J hose. The blue 1205 and PN1 sure looked silly with that golden hose, but worked fine after that. I tried using the old original blue hose one time after that, just to see if i could get sparks to fly, or what would happen. When i turned the vacuum on the PN did work,,and sparks did not fly out of the little hole, but after a few min there was a terrible burning smell. So, i took the hose off once and for all and threw it away. |
Post# 99140 , Reply# 19   5/26/2010 at 00:46 (5,081 days old) by electrolux~137 ()   |   | |
Post# 99142 , Reply# 21   5/26/2010 at 00:48 (5,081 days old) by electrolux~137 ()   |   | |
OTOH, the Model R, an economy model, did have the PN port down by the front wheels -- a pair of small casters. |
