Thread Number: 8169
Parents out at last so chance to take one or two photos! |
Post# 90881   2/7/2010 at 07:29 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
I got chance to Hoover the dining room with my 900 yesterday since dad, who usually sits there for most of the day, had gone out with my mum and sister, plus the dogs had been confined to the kitchen. There was time to clean up the dog hairs off the floor, in order to take some decent pictures! Would have taken more but then the switch suddenly fell to bits on one of my new aquisitions, so had to fix that! |
Post# 90882 , Reply# 1   2/7/2010 at 08:14 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90883 , Reply# 2   2/7/2010 at 08:21 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Thought to start with that this plant label would be suitable.. WRONG! The plastic turned out to be too brittle, so in the end I used some blue plastic off a Nat West Bank Ring Binder! Well, it was the right thickness and a lot more flexible than the plant label...but this picture showing the label gives you the general idea. I drew around the damaged insulator onto the new plastic, using the original insulator as a template, then adding on a bit by guesswork! Stephen |
Post# 90886 , Reply# 3   2/7/2010 at 08:31 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
The motor runs surprisingly well for such an old machine, bearing in mind that the commutator looked a bit dirty and that the brushes had been turned round by 90 degrees, one of them a little burned on one of the faces.. I turned the brushes round before I started it up. The only other thing I had to do was to flick the switch a few times and clean up the prongs protruding from the motor casing, where a previous owner has fitted a Black and Decker connector to get the thing going! This obviously isn't the right one and the prongs are smaller than the sockets but the side of the sockets bear on the prongs when connected. However, on one occasion when it refused to start, it appeared to be making a bad connection here. |
Post# 90887 , Reply# 4   2/7/2010 at 08:31 (5,185 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 90888 , Reply# 5   2/7/2010 at 08:36 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
The frayed cable was my doing, since I was in a rush to get the Black and decker connector back together after doing a few continuity checks and jammed part of the cloth covering, tearing it a little. I'll sort that out later. Here's another close-up picture with the machine running. I was trying to show the sparking and there is a small amount, which is normal but here I can't see anything in the picture! |
Post# 90890 , Reply# 6   2/7/2010 at 08:42 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90891 , Reply# 7   2/7/2010 at 08:44 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90892 , Reply# 8   2/7/2010 at 08:47 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90893 , Reply# 9   2/7/2010 at 08:55 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90895 , Reply# 10   2/7/2010 at 09:01 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90896 , Reply# 11   2/7/2010 at 09:04 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90937 , Reply# 12   2/7/2010 at 12:42 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90938 , Reply# 13   2/7/2010 at 12:45 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90939 , Reply# 14   2/7/2010 at 12:54 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
I got the special running by re-wiring it and also replaced the carbons, one of which was worn down to about 1mm or less!..so that was going to go any time. One of the wheels was worn flat, due to it being seized on its shaft - will folk ever learn to oil them? The front wheel shafts had been replaced with bolts, which weren't big enough, so I found some better ones and got rid of most of the wobble. I made up a crude temporary bottom plate, since that was missing; I'll probably have to look into getting some of them made eventually. At some stage I hope to get round to repainting the chassis but don't want to overdo it. |
Post# 90946 , Reply# 15   2/7/2010 at 14:44 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
I was pleased to recently find this Premier Duplex cleaner to complement my Premier Junior. This appears to be a slightly later model than the Junior, since the wheels are not in line with the nozzle but behind it. Also, the bag looks like it's for a later model Premier, though it certainly looks the part and has the same fitting. |
Post# 90947 , Reply# 16   2/7/2010 at 14:47 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90948 , Reply# 17   2/7/2010 at 14:50 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90949 , Reply# 18   2/7/2010 at 14:55 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90950 , Reply# 19   2/7/2010 at 15:00 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Here's my GEC Magnet. This is quite an unusual machine to find in the UK. I believe that Jack used to have one and sold it. Possibly, it is even the same one, though I didn't buy it from him. The switch is operated automatically when the handle is lowered. The machine runs well and has been re-bristled at some stage. I was lucky to spot a bolt lossening on the rear wheel mounting, before it came undone inside the motor.. |
Post# 90951 , Reply# 20   2/7/2010 at 15:02 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90952 , Reply# 21   2/7/2010 at 15:07 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90953 , Reply# 22   2/7/2010 at 15:09 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90954 , Reply# 23   2/7/2010 at 15:12 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90955 , Reply# 24   2/7/2010 at 15:14 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90956 , Reply# 25   2/7/2010 at 15:14 (5,185 days old) by bagintheback (Flagstaff, Arizona)   |   | |
Post# 90957 , Reply# 26   2/7/2010 at 15:16 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90958 , Reply# 27   2/7/2010 at 15:20 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90959 , Reply# 28   2/7/2010 at 15:29 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
In the meantime, teddy is looking for a bag for his Westinghouse vacuum cleaner. This is a 240 volt model but I'm unsure whether anything similar was made in the US. If nothing materialises I think I'll eventually try to bend a piece of aluminium to form some kind of tube and make some suitable slots and protrusions, in order to screw the flange onto the chassis and secure a bag onto the flange, which will have to be tailored to fit. Any ideas? There's no rush..but Teddy doesn't want to choke on dust.. Stephen |
Post# 90961 , Reply# 29   2/7/2010 at 15:56 (5,185 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 90979 , Reply# 30   2/7/2010 at 20:10 (5,185 days old) by kenkart ()   |   | |
Especially the Goblins, that is something you never see in the U S !!! |
Post# 91207 , Reply# 32   2/10/2010 at 16:28 (5,182 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Dave, Hans & Charles, Thanks for the comments! I'm glad you like the machines and my attempts to improvise. Sorry for the slow reply but I've been on 12 hour shifts for the last three days so I'm getting home rather tired to check emails...but at least I'm off tomorrow! I could have fitted a non-standard switch on the first machine shown above (don't know its name yet!) but wanted to keep it as original as possible, bearing in mind it's for my own collection. Charles, the Westinghouse was indeed a splendid find and runs well with a very decent suction, which is especially good without the missing bag! It's the only one I've seen of this type. Stephen |
Post# 91209 , Reply# 33   2/10/2010 at 16:41 (5,182 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 92541 , Reply# 34   3/1/2010 at 14:23 (5,163 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 92543 , Reply# 35   3/1/2010 at 14:27 (5,163 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 92545 , Reply# 36   3/1/2010 at 14:30 (5,163 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 92546 , Reply# 37   3/1/2010 at 14:33 (5,163 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
