Thread Number: 809
high speed swicth on hoover convertible |
Post# 8392   1/15/2007 at 18:36 (6,308 days old) by vacuumboy95 ()   |   | |
Hi I was woundering how to get the high speed to stay on. |
Post# 8395 , Reply# 1   1/15/2007 at 19:04 (6,308 days old) by convertible68 ()   |   | |
Question: How does the switch activate, and where is it mounted on the machine? Also, what is the model number of the Convertible you have? |
Post# 8397 , Reply# 3   1/15/2007 at 20:20 (6,307 days old) by kirbyultimateg (Troy Ohio 45373 USA)   |   | |
Kirby Dual Sanatronic 50-Sentria uses a 2 speed motor with automatic shift just like the Hoover Convertibles. High gear is used for hose, Low gear is used for floor. Kirby Diamond Edition has the automatic shift motor too but it has a manual 2 speed Normal/Delicate switch. |
Post# 8403 , Reply# 4   1/16/2007 at 05:31 (6,307 days old) by vacuumboy95 ()   |   | |
the model is 593.it's mounted right below the right rear wheel.the one with the spring on it so you can adjust the height on it. |
