Thread Number: 7692
Help with Hoover Innovation |
Post# 84844 , Reply# 2   11/27/2009 at 21:41 (5,234 days old) by extraditgitzz ()   |   | |
Use a Hoover Type A bag for your Innovation "formerly type B" according to the package. Use it sparingly as parts aren't available.... It is a shame as they are great machines. |
Post# 84893 , Reply# 4   11/28/2009 at 21:21 (5,233 days old) by kirbyvertibles (Independence, KS)   |   | |
Post# 84900 , Reply# 5   11/28/2009 at 22:21 (5,233 days old) by extraditgitzz ()   |   | |
Wouldn't you use the bag that Hoover recommended as a replacement to the type B, which would be the TYPE A?? |
Post# 84919 , Reply# 7   11/28/2009 at 23:38 (5,233 days old) by vacman117 (Chicago, IL)   |   | |
Post# 87497 , Reply# 8   12/30/2009 at 13:52 (5,201 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
I used to get a lot of Turbomasters in for service/repair and found that the activators rarely needed changing..or even the belts; it was usually some other problem, like a broken fan or field winding, damaged door or cable..unless it was the permabag models - the U5132s, which used to block up for fun! I expect that the activators are obsolete now, though I've probably got one or two left, just in case. Even the new ones look worn to the un-trained eye. This is because there is a ridge sticking out of the roller, so the brush length is not as long as on most other machines. Stephen |
