Thread Number: 7678
Electrolux Wet / Dry Vacs |
Post# 84742   11/26/2009 at 12:39 (5,257 days old) by collector2 (Moose Jaw, Sk)   |   | |
Post# 84761 , Reply# 2   11/26/2009 at 23:45 (5,257 days old) by caligula (Wallingford, Connecticut)   |   | |
Hi Doug, Hi John: The C-A. was the first and only wet/dry commercial Electrolux. I was lucky enough to use one. I believe it was introduced in 1962. Yes, there was a spacial insert with a float baffle thingy that shut the machine off when it had taken in too much water. Exactly like with dirt in the dust bag. Why was it the only one? the answer is simple, somebody in the Electrolux engineering department messed up. It was a wet/dry vacuum cleaner, right? so why wasn't there a grounded plug? Somebody got a bad shock, contacted the Electrolux Corp. and threatened a lawsuit. I don't know if that was the only reason but Electrolux never took the chance again. They redesigned the next model the C-B. Also Electrolux etched a note on the future machines for both household and commercial use reading."WARNING Electrical shock may occur if used outdoors or on wet surfaces." Actually the C-A was a really nice machine. There was a storage area for the cord, standard hose, (which also came in ten and twelve foot style), two aluminum wands, combination rug and floor tool, crevice tool, combination dusting brush/upholstry tool, extra filter bags and instruction book. There were two clips for holding the power nozzle, which, by the was was designed without the long plastic wand, instead there were two steel wands, and the detachable cord with hose and wand clip . That's right the nozzle could go right on the hose handle. As for optional equipment. There was a special rubber hose that was ten feet long (the twelve footer was also available.) There was a special wet pick-up floor tool outfitted with a squeege thingy and an extra wide foor brush. I just acquired one of these and if you go to "Electrolux Dude's pictures, the last is the C-A which is now mine. Note however, that his power nozzle has the long plastic handle, therefore not orrininal! As for the CBW and CW I have no info on them but would love to see pictures. As for the C-A, it had great suction. That is all the information I have for now guys. Alex Taber |
Post# 85320 , Reply# 3   12/4/2009 at 20:13 (5,249 days old) by collector2 (Moose Jaw, Sk)   |   | |
Post# 85323 , Reply# 4   12/4/2009 at 20:15 (5,249 days old) by collector2 (Moose Jaw, Sk)   |   | |
