Thread Number: 7476
Electrolux Carpet Attachment. |
Post# 82509   10/18/2009 at 02:49 (5,303 days old) by electroluxkirby ()   |   | |
What is the top of this attachment used for? |
Post# 82510 , Reply# 1   10/18/2009 at 03:50 (5,303 days old) by caligula (Wallingford, Connecticut)   |   | |
Calling Charles Richard Lester! Charles, correct me if I'm wrong, but I think the answer is that the top of this tool is what became known as the "Gleaner" in later models. For those of you who don't know the early Electrolux models XXX (30), XX (20), LX (60), LXI (61), and E. The "Gleaner" combed the carpet removing thread, dog/cat fur, and so on. It was also used on area rugs. On the XXX and so on there was a bar outfitted with teeth on the underside of the tool. A leaver was moved to rotate it and the smooth surface meant the gleaner was in "off" position. The rug nozzle shown here is from the model XI (11), XII (12), or the early model XXX. Again, if I'm wrong, please correct me charles. Alex Taber. |
Post# 82516 , Reply# 2   10/18/2009 at 08:49 (5,303 days old) by electroluxkirby ()   |   | |
I will have to try this out on my area rug in the laundry room. Thanks for the info. |
Post# 82518 , Reply# 3   10/18/2009 at 10:08 (5,302 days old) by vacman117 (Chicago, IL)   |   | |
Post# 82528 , Reply# 4   10/18/2009 at 12:40 (5,302 days old) by joe22 ()   |   | |
gleaner moved from top suction opening to the bottom, when ??? the top concentrated suction for stubborn things like threads, hair, etc. narrow space cleaner is the name lux uses for a *crevice tool* |
Post# 82545 , Reply# 5   10/18/2009 at 16:55 (5,302 days old) by caligula (Wallingford, Connecticut)   |   | |
The earliest patent file I know of using some sort of "Gleaner" is that of Gustaf E. Lofgren. Patent # 2,027,543. Filed Oct. 7, 1933 and patented Jan. 14, 1936. During this time the bar thingy at the bottom of the rug tool was patented by George. H. Cranmer. Patent #2,025,442. Date filed Jan. 22 1935 with the patent issued Dec. 24, 1935. Both would be for the Electrolux model XII (12). Gusaf E. Lofgren was an electrolux fixture from the time the factory opened in Old Greenwich, Connecticut in 1933. His job was design and research, meaning that most of the patents for attachments, tools other devices like the ejection system were his. This means that the models XXX, XX and others were his. But not the famous model LX, that was the design of Leon P. Borkoski, patent filed May 4, 1951 and issued Oct. 6 1953. There were at least 5 designs for the rug tool you have shown. There were several for the model XXX and at least 2 for the LX. For over 30 years Gustaf E. Lofgren and his crew turned out things like the Cord winder, B8 polisher, turbo polisher, (1947) and the Power Nozzle. Most of my information is from my own patent research, while other information comes from the book "ELECTROLUX CORPORATION--- the first forty years." Lofgren was the Vice Predident of marketing at the time that book was written in 1964. Alex Taber |
Post# 82548 , Reply# 6   10/18/2009 at 17:10 (5,302 days old) by electroluxkirby ()   |   | |
Can the cloth bags for the Model XXX be washed? |
Post# 82549 , Reply# 7   10/18/2009 at 17:58 (5,302 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 82550 , Reply# 8   10/18/2009 at 18:03 (5,302 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 82554 , Reply# 9   10/18/2009 at 18:53 (5,302 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 82555 , Reply# 10   10/18/2009 at 18:59 (5,302 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
and the bottoms. Similar yet distinctly different variations. Now, in the next generation of Electrolux flip-over tools most have a gleaner combed machine cut rod at the edge of the wide nozzle that can be rotated on/off. There is a variation gleaner type rod that is helical knurled all around and can not be 'turned off' - it simply has a surface texture that grabs those pesky threads. |
Post# 82570 , Reply# 12   10/18/2009 at 23:15 (5,302 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
It's true, Norm. The 1932 nozzle does not have a weight but the other three all have a pig iron slug weight (most often rusted) in a form fitting cast shape clamped in place when the halves are screwbolted together, as does the GE Cycolac plastic flip-over floor & rug tool for the early Swiveltops and Roll-Easy. It does take a short practice session with wrist action but once mastered it's done with a supreme casual flippancy. This is one improvement they latched on to early as it is not easy to flip over an un-weighted nozzle without involving feet or brute floor banging force. :-) Dave |
Post# 82571 , Reply# 13   10/18/2009 at 23:41 (5,302 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
The red, green and beige painted cast aluminum Canadian Electrolux nozzles for the 80 and AP series is also weighted on one side. American Luxs discontinued this flip-over style nozzle with the LXi and with the 1954 Model E, introduced the Combination Tool that required removing the inlet box from the nozzle and flipping that over... CanLux soldiered on with the much more convenient flipover nozzle well into the mid 1980s. Series 83-86-88 tilted under it`s own weight... |
Post# 82573 , Reply# 14   10/18/2009 at 23:58 (5,302 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 82574 , Reply# 15   10/19/2009 at 00:21 (5,302 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 82577 , Reply# 18   10/19/2009 at 01:14 (5,302 days old) by electrolux~137 ()   |   | |
Here's a photo showing the evolution of all the Electrolux floor tools. I've posted it here before, but since it's topical to this thread I'll post it again. |
Post# 82590 , Reply# 19   10/19/2009 at 10:36 (5,301 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Of course, I meant to write `discontinued this flip-over style nozzle AFTER the LXi`. Thanks Charles for filling in the gaps - I was mainly making the point that Canada Electrolux continued the flip-over nozzle for decades after USA Lux abandoned it. I`m in Sarnia with Pete right now but when I get home I`ll be checking that I have the correct nozzles with the appropriate models. Thanks for the panoramic photo with labels - I`ll be printing that reference for sure. Dave Ah yes, the illusive Tuftor... |
Post# 82591 , Reply# 20   10/19/2009 at 10:39 (5,301 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 82592 , Reply# 21   10/19/2009 at 10:40 (5,301 days old) by caligula (Wallingford, Connecticut)   |   | |
Post# 82594 , Reply# 22   10/19/2009 at 10:52 (5,301 days old) by arh1953 ( River Park, in Port St. Lucie, Florida)   |   | |
Post# 82599 , Reply# 23   10/19/2009 at 12:35 (5,301 days old) by caligula (Wallingford, Connecticut)   |   | |
Post# 82624 , Reply# 24   10/19/2009 at 18:01 (5,301 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 82625 , Reply# 25   10/19/2009 at 18:02 (5,301 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 82633 , Reply# 26   10/19/2009 at 18:58 (5,301 days old) by caligula (Wallingford, Connecticut)   |   | |
Thank you Charles Richard and Dave for those great pictures of the Electrolux rug tools. Reminds me of the ones that are now boxed up and in storage. With the exception of the two Model V tools and the plastic war issue XXX tool, I have every one of those. Check my pictures and my "Electrolux Wall Of Fame" to see these. Anybody who has the "Companion" (ride on too holder) for the XXX and LX, please post pictures for others to see. And finally if any of you have the booklet for the Model LX, how about letting us see that too. Thanks, Alex Taber |
Post# 82651 , Reply# 28   10/19/2009 at 21:03 (5,301 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 82658 , Reply# 29   10/20/2009 at 00:14 (5,301 days old) by briankirbyclass (Eudora Kansas)   |   | |
Post# 82659 , Reply# 30   10/20/2009 at 00:26 (5,301 days old) by em-tor64 ()   |   | |
My XXX with attachment carrier..... |
Post# 82660 , Reply# 31   10/20/2009 at 00:27 (5,301 days old) by em-tor64 ()   |   | |
One more....... |
Post# 82666 , Reply# 32   10/20/2009 at 09:22 (5,301 days old) by luxg ()   |   | |
Michael, that is a beautiful XXX!!! The bumper on the rug nozzle looks perfect!! |
Post# 82669 , Reply# 33   10/20/2009 at 09:34 (5,301 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 82671 , Reply# 34   10/20/2009 at 09:47 (5,301 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
The Companion clips to the bag door latch fittings on the 57. No clip for the crevicetool. It was an available option in 1953 so you could have gotten one for your earlier 55 or 30. Kinda scarce and I have only the one. My latest Z57 above from the Stratford Lady last week has the later all chrome flip-down cordwinder. I've included a few additional tools from the 1939-50 Model 30 and 50 series Loafs. The correct woven hose is a brown/beige hose that matches the 'tweed' pattern leatherette. Until I find one I pair up the red Z8X hose rather than the two-tone gray common to the 30 & 50. Note on suction regulators...I don't think the ladies used or liked it much. Every CanLux hose I've found invariably has the valve ring Scotch, Electrical or Masking taped in place and of course I clean it up to restore function. |
Post# 82672 , Reply# 35   10/20/2009 at 09:54 (5,301 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 82727 , Reply# 37   10/21/2009 at 01:02 (5,300 days old) by caligula (Wallingford, Connecticut)   |   | |
Nice to see the word kompanion etched into the tool holder. Thank you for posting them. To the member who posted the youtube Model LX ejection process, sorry, I couldn't find it. several nice clips including my friend Charles Richard, but no Electrolux LX and no ejection thingy either. Are there any Electrolux collectors out there who were salesmen around the time that model was sold. Love to talk to any old timer about the home demo of that model. Alex Taber |
