Thread Number: 7467
Kirby Legend II nozzle Rattle |
Post# 82393 , Reply# 1   10/14/2009 at 22:33 (5,300 days old) by myvacsrock (USA)   |   | |
Brushroll bearings? i m guessing when the vacuum is pushed forward the brushroll comes in contact with the carpet and it rattles. Just a guess.. |
Post# 82414 , Reply# 2   10/15/2009 at 10:18 (5,300 days old) by bagintheback (Flagstaff, Arizona)   |   | |
Post# 82424 , Reply# 3   10/15/2009 at 18:51 (5,299 days old) by gsohoover (Reidsville, NC)   |   | |
The end caps on the brushroll may be broken maybe its time to get a new brushroll. |
Post# 82447 , Reply# 5   10/16/2009 at 06:43 (5,299 days old) by vinvac (Dubuque IA)   |   | |
Post# 82465 , Reply# 6   10/16/2009 at 17:33 (5,299 days old) by a007kirbyman (--->> Originally My Mom <<--- (now Wisconsin))   |   | |
Morgan, You are on the right track... ...I may be incorrect; however, I believe it may actually be the (4) four tabs the brushroll slips into (2) two on each end. They may & should be slightly bent inward to tighten the fit for the brushroll end caps. (imho) Hope this helps. email if add'l help is needed. hagd all Bill |
Post# 411799 , Reply# 10   7/20/2019 at 19:44 (1,734 days old) by Rowdy141 (United Kingdom)   |   | |
A loud vibration rattle has also developed on my Legend II.
It's not Roller Bearings; the Roller is brand new. I tightened the Roller Support Tabs (bent them inward); no difference. Checked & adjusted roller height; no difference. Checked Motor Casing 'O'-Ring Gasket where the Brushroll Head meets it; all present & correct. Swivel Turnbutton is very tight; gripping head securely. Headlight is very tight; it wouldn't vibrate. Now I'm replacing the rectangular Rug-Plate Felt Gasket. |
Post# 411815 , Reply# 11   7/20/2019 at 23:19 (1,734 days old) by Lesinutah (Utah)   |   | |
Post# 411837 , Reply# 12   7/21/2019 at 09:28 (1,734 days old) by sptyks (Skowhegan, Maine)   |   | |
Post# 413749 , Reply# 14   9/13/2019 at 09:13 (1,680 days old) by Rowdy141 (United Kingdom)   |   | |
Kirbfan94,
I solved my Kirby nozzle rattle. Thought I'd share the solution in case it helps. The problem was in fact, in three areas. Rugplate rattle. New gasket helped, but deep vibration persisted. One End support brackets needed squeezing slightly tighter. Main problem: New Brushroll's height was out. (I thought it was okay). Needed 2 1/2 undo turns on each end-screw to retract roller slightly. Hope it helps. |
