Thread Number: 7259
Does this come apart? |
Post# 80280 , Reply# 1   9/7/2009 at 12:26 (5,316 days old) by meba2233 (Webster Groves, MO)   |   | |
Although this is not a top of the line model, it is in above average condition. Here is a pic of the base. |
Post# 80330 , Reply# 3   9/7/2009 at 18:31 (5,315 days old) by eurekaprince (Montreal, Canada)   |   | |
The only way you can split the handle in two is if you break these buttons off (which is going to be really difficult to start with). You will never get the two parts back together again unless you have replacement buttons. Unlike the top of the line Eureka uprights which use metal two-piece bolts to assemble the handle halves, the cheaper ones with the plastic handle are assembled using "one-time-only" plastic buttons that snap into place to hold the two halves together. If you break these buttons off to dis-assemble the handle, you may have to improvise replacements with some nuts and bolts when you decide to put the two pieces back together again. Nice Eureka - no head scratches on the top of the hood! That's unusual! EP Brian |
