Thread Number: 7204
Miele S7 Hose Issue... Again! |
Post# 79547   8/29/2009 at 19:24 (5,352 days old) by vacfanatic (Omaha, NE)   |   | |
Well I had my S7 hose replaced under warranty back on 6/22/2009, and it's already showing symptoms of the same thing the last one did. I'm sure the problem is the hose material and spiral coil cannot stand up to the intense suction of this cleaner. If you block off the suction at the end of the hose, let's say if you were cleaning a real sense fabric etc, this is what the hose does. It's going back to it's normal shape almost all the way, but this is what the last hose did before it was pretty much useless. I had to request a new hose when it would crush itself and remain crushed even during normal vacuuming with the cleaner. I think Miele needs to go back to the drawing board on the hose material they chose, because it's clearly an issue. I've heard from another member that he's heard of about 3 other reports of the same problem. I think that using the crevice tool, and the turbo hand tool are what is causing the hose to "stress out". The turbo tool does not run well unless the suction is on full blast, and I think it causes too much pressure on the hose and causes it to "smush". Same thing with the crevice tool after extended use. Won't be long before this hose is worthless like the other one was. I'm just a bit pissed that I'm having to deal with this again. Emailed Miele, we'll see what they say. I better not get some canned response from them either or this cleaner's going on eBay - I've used the cleaner maybe 12 times since I got the hose replaced, and it's already becoming an issue again. Very frustrating!!! First pic is the replacement hose 2 months ago. Now look at it! Andrew |
Post# 79548 , Reply# 1   8/29/2009 at 19:25 (5,352 days old) by vacfanatic (Omaha, NE)   |   | |
Post# 79549 , Reply# 2   8/29/2009 at 19:26 (5,352 days old) by vacfanatic (Omaha, NE)   |   | |
Post# 79550 , Reply# 3   8/29/2009 at 19:27 (5,352 days old) by vacfanatic (Omaha, NE)   |   | |
Post# 79551 , Reply# 4   8/29/2009 at 19:29 (5,352 days old) by vacfanatic (Omaha, NE)   |   | |
Post# 79552 , Reply# 5   8/29/2009 at 19:32 (5,352 days old) by vacfanatic (Omaha, NE)   |   | |
Post# 79561 , Reply# 6   8/29/2009 at 23:02 (5,352 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
From my engineering materials perspective, you are absolutely correct, Andrew. I checked out the S7 at the local Canadian Tire store here this morning. It too is beginning to show signs of distortion from store demonstrations and try-outs. In order to have this hose extend and expand to the ratio Miele desired, there is far too much vinyl span between the coils that folds in when contracted. If the vinyl was a smidge thicker it would hold it's shape better but it would still close down the useful inside diameter of the hose. As it is, the compacted vinyl effectively narrows the inside diameter of the hose by 2/3rds, leaving a 3/4" to 1" dia airpath. The strong suction pulls the folded ribs against one another in domino fashion and since the spring coil is also of a lesser thickness than required, it is permanently distorted out of round over time and takes on an oval offset. This tilted offset adopts and sets that shape with continued pressure under suction the more the cleaner is used and the weak coil metal cannot resist the torsional forces twisting it over on an angle because the suction is trying to flatten the hose completely closed, like a roll of coins falling over on its sides outside the wrapper. Resulting in the collapsed condition you have experienced twice now. As we know, this type of marvelously expanding vinyl hose under any suctional resistance other than an unrestricted nozzle or tool has a natural inclination to contract itself and pull back toward the vacuum quite forcefully when a hand is placed over the hose end throttling back the airflow. The hose on the New Connie is of the same construction but the span between the coils is less, so this does not happen. Same for the vinyl hose on the Kenmore Premalite...they stretch out impressively and contract back to their original tubular shape without distortion. But they too try to contract themselves when the airflow is interrupted or blocked. This is a tradeoff to have an extremely flexible snaky hose that can reach all the way to the top of a flight of stairs. Miele engineers have simply taken the tradeoff a bit over the edge with too much and too thin vinyl jacketing and a cheaper weaker coil wire. It *could* be there was a bad initial batch of Miele hose material that has 'found' its way in to overseas export S7s from the European factory and this same bad batch has been used to supply replacement hoses to the same market. I suspect a side-by-side hands-on comparison with a European spec S7 hose would make this obvious and perhaps one of our other-side-of-the-pond members could measure the inside dia of their collapsed hose and perhaps a picture down the throat to compare with US machines. I'll go back tomorrow to photograph the throat opening of the S7 at CanTire. Miele is facing a public relations & consumer nightmare until this hose material is recalled and replaced, I'd say. Such a major flaw is inexcusable on a +$500 machine. Below, the collapsed throat diameter of the New Constellation; by comparison the S7 hose looks lined with a 1/2" thick layer of cholesterol. :-) Dave |
Post# 79562 , Reply# 7   8/29/2009 at 23:05 (5,352 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 79563 , Reply# 8   8/29/2009 at 23:30 (5,352 days old) by vacfanatic (Omaha, NE)   |   | |
Dave, Thanks for covering all the real technical details which you are much more experienced and educated on that I am. All I could come up with was the term "smushed" LOL. I know that Miele will probably have to do something about this or they will surely damage their reputation as such a high end appliance manufacturer. In the meantime, I've dusted off my Kirby Ultimate G Diamond and have her ready to take over for the S7. Until the Miele engineers come up with a working replacement hose, I'm going to just park the S7. Sad... $1000 vacuum cleaner and the simplest of parts, a freaking hose, is defective. I'm not bashing Miele, I'm just frustrated is all. Wish they had the same hose that is on my Hoover Windtunnel 2 Bagged - freaking LOVE that hose, it never smushes, and the W2 has a lot of suction like the S7 does. Thanks again Dave for the additional details of the hose design. -Andrew |
Post# 79565 , Reply# 10   8/29/2009 at 23:59 (5,352 days old) by xraytech ()   |   | |
Andrew, That sucks that you are having this problem again, I would have expected more from such an expensive vacuum. Is there any way that you may be able to return it? Sam |
Post# 79566 , Reply# 11   8/30/2009 at 00:13 (5,352 days old) by vacfanatic (Omaha, NE)   |   | |
Post# 79569 , Reply# 13   8/30/2009 at 05:25 (5,352 days old) by seamusuk (Dover Kent UK)   |   | |
(Oops, forgot I was signed in as Seamus on his laptop; this is Jack, hehe!) :P |
Post# 79576 , Reply# 14   8/30/2009 at 09:13 (5,351 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Aw shucks, Andrew, smushed is the perfect succinct descriptive of what that hose is doing to itself. Ever curious, I wanted to analyze exactly why this is happening - a combination of inadequate coil wire material chosen, not up to the task's torsional forces and a severely reduced throat diameter - gradual smush. Rather than contact Customer Support I would follow the links all the way to the top of Miele USA and make a big disappointment noise. I'm sure they are hearing plenty of noise back at corporate from the dealers getting returns of an otherwise excellent upright cleaner. Consumers need to take the Bull by the horns and let corporate Miele know we are not satisfied about this hose but we love the S7. Because Miele so proudly trumpets their exhaustive testing procedures we must get them to acknowledge that the hose is defective from it's inception, a better hose (like the New Connie) is the easy fix and they must get these new hoses on to the new S7 production line and into the hands of previous buyers quickly and with apologies. It is not the franchised dealers' fault but they are the ones getting the flak while Corporate dithers away sending out in-stock replacement hoses with the same problem. One would hope Miele has a fix in the works but they certainly aren't advertising it. :-( You can be sure Corporate knows all too well they have a problem with this lemon of a hose. Wouldn't it be nice if they would swallow their pride and contact every purchaser of an S7 and make it right? Well, the squeaky wheel gets the grease, as they say. Later today when I have pictures of the S7 throat diameter I'm going to email my own letter of complaint and analysis to Miele Corporate in Canada and the USA and wait for whatever response I get. I don't even own an S7 yet but they don't need to know that. :-) I feel the S7 series is a future collectible and I hope to have one one day...but not with a defective hose. Dave CLICK HERE TO GO TO aeoliandave's LINK |
Post# 79592 , Reply# 16   8/30/2009 at 14:57 (5,351 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Ok, here's picture proof of what's wrong with the choice of S7 hose vinyl...it's too thin to hold it's ring shape as it expands and you can see how deep the inner fold protrudes into the airstream. I compared to every other stretchy vinyl hose vacuum brand in Can Tire and every one of the others is thicker vinyl with a lesser span between coils and does not exhibit this wrinkled effect as you pull the hose out.
Post# 79593 , Reply# 17   8/30/2009 at 15:00 (5,351 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 79602 , Reply# 18   8/30/2009 at 17:21 (5,351 days old) by eurekaprince (Montreal, Canada)   |   | |
But it happened in China well before I opened the box here in Canada. When I saw that the Hudson Bay department store was deep-discounting the new stainless steel Constellation, I bought one for me and one for a friend. The Bay was originally selling these for CAD400.00, but it dropped to a beautiful CAD180.00 at some point, and I could not resist. Though Consumer Reports rated it poor for carpet cleaning (because it only comes with an air-driven turbo rug nozzle), it rated all other aspects as excellent, including air-flow through the hose and filtration. Since I use my classic Eureka upright on carpets, this was going to make a fine companion for all other cleaning. When I opened both boxes, I was really angry to see that both hoses were "smushed" just like these Miele's! It looked like both were taken from the bottom of the pile of hoses the packer was using to fill his Constellation boxes back in TTI-land in China. No matter how much you stretched them, the hose contracted into the "smushed" state. It may have even happened after the hoses were placed in the carton. They both were not wrapped around the Constellation bases as they should have. Instead, they were sitting in the cardboard tool tray at the top of the box, but "folded" in half and squished into a corner. This is what may have caused the deformations. I brought both hoses back to the store with my receipts and got two replacements which were much better. I was not going to accept mediocre equipment on Day One of using a brand new vac - no matter how inexpensive. Wishing you much luck with Miele. This will be a real test of how responsive the company is to consumers' needs. Eurekaprince Brian |
Post# 79606 , Reply# 19   8/30/2009 at 18:50 (5,351 days old) by piano_god (British Columbia, Canada)   |   | |
The five-year warranty is a promotion in Canada only that is currently set to end on September 31st. This applies to all machines, including the chinese made S514 and S518. The seven-year warranty still applies to the vacuum motor only. Canadian Tire has been having a tough time selling the S7280 Mistral vacuum, so much so that Costco was sent a bunch to sell. Makes me think that the Mistral may not be carried at Canadian Tire for much longer... |
Post# 79607 , Reply# 20   8/30/2009 at 18:55 (5,351 days old) by piano_god (British Columbia, Canada)   |   | |
Post# 79609 , Reply# 21   8/30/2009 at 19:53 (5,351 days old) by vacuumfreeeke ()   |   | |
Sorry that is happening to you again! Especially on such a nice machine. Must be terribly frustrating! |
Post# 79630 , Reply# 22   8/31/2009 at 08:11 (5,351 days old) by vacfanatic (Omaha, NE)   |   | |
Post# 79636 , Reply# 23   8/31/2009 at 11:27 (5,350 days old) by vacfanatic (Omaha, NE)   |   | |
I have been contacted by a representative at Miele and am working with them to provide more details of the hose problem to Miele. I just wanted to let everyone know how fast of a response I have received - pretty impressive for customer service if you ask me! Hopefully it will be sorted out soon enough so I can get back to cleaning in luxury :-) I'll let you know how things turn out. Thanks, Andrew |
Post# 79695 , Reply# 27   9/1/2009 at 11:09 (5,349 days old) by vacfanatic (Omaha, NE)   |   | |
Chris, They emailed me direct from Miele after I sent in a post sale complaint about the hose being "smushed again". I'm waiting to hear from another contact at Miele to discuss the problem. I believe they are trying to get another problem report about the hose so they can officially address it if they have not already, but that's just my speculation. I'm just waiting for a call or email. Andrew |
Post# 80201 , Reply# 29   9/6/2009 at 13:26 (5,344 days old) by vintagehoover ()   |   | |
And to think...a 'tested-for-20-years' MIELE! Never had this issue with any of my "Die-soons". Just sayin'... CLICK HERE TO GO TO vintagehoover's LINK |
Post# 80219 , Reply# 30   9/6/2009 at 17:06 (5,344 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 80269 , Reply# 31   9/7/2009 at 11:15 (5,343 days old) by vacfanatic (Omaha, NE)   |   | |
I'm meeting with the midwest Miele floorcare representative today to discuss and show what is happening again with my second hose. The information will get relayed to Miele and hopefully we'll be able to find a solution to my problem. If others are having the same issue that I am, please contact Miele so they get more reports of the issue. Unless they start receiving feedback from those affected, I would not expect any resolution. I'm going to ask that once this hose completely fails like the last one (and I can already tell it will in a few months), I'd like to be able to send the hose directly to Miele vs exchanging it through my dealer. Want to make sure the defective hose is reaching the correct hands at Miele so they can see first hand what I'm experiencing. In the last few days of cleaning with the S7, the hose has become even weaker. Now when you block off the suction temporarily, the hose "squashes" and then in a few spots wont unsquash. I put a brand new bag in it to do this test. Airflow indicator was all the way clear, then after the "squash" test, it was completely red, all the way. You have to jiggle, pull, and fuss with the hose to get it to restore airflow. (This is really inconvenient when using the Turbo Tool!). The first hose, was so bad when I had to ask for a replcement, I literally could not even use the hose for anything on full power. Instant "squashing" and you'd have to turn the cleaner clear off, and fiddle for a few minutes to even get it to be somewhat functional. Didn't last long though. I'll let you guys know how my visit goes! Kind of nervous :-) Andrew |
Post# 80275 , Reply# 32   9/7/2009 at 11:42 (5,343 days old) by bagintheback (Flagstaff, Arizona)   |   | |
Post# 80276 , Reply# 33   9/7/2009 at 11:51 (5,343 days old) by chestermikeuk (Rainhill (Birthplace of the Railway),England, UK.)   |   | |
No need to be nervous Andrew , you are the CUSTOMER and having identified an issue I`m sure they will oblige!! just have all your paperwork & sales documentation, and simply explain the issue, if this person as part of the Miele organisation doenst want to play ball then simply thank him for his time and come away..then contact Miele HQ USA and copy in Miele Germany, politely explaining the vac club!!! that`l sort it!!! Jack, are you saying yours is doing the same??? |
Post# 80304 , Reply# 35   9/7/2009 at 16:17 (5,343 days old) by vacfanatic (Omaha, NE)   |   | |
Well I met the representive and had a wonderful visit. My concerns of the hose were expressed and demonstrated. The rep had not seen this before, and was quite shocked the hose would do such a thing! I'm sure that not all of the hoses are doing what mine have, but maybe I just have used it way more than most do and it's stressing? I have a multi-level home combined with a touch of OCD, so it's not uncommon for me to have the S7 running for 1.5 hours - 2 hours on a cleaning spree. The hose gets a LOT of use. Miele has arranged to have a new hose ordered for me, and once it comes into my dealer I'll get to exchange it again. This 2nd defective hose will be sent into Miele per the rep's discussion and will surely be sent to the designers etc. I'm confident that Miele will take the issue seriously and work to resolve this. My only complaint on the S7 so far. Other than that, I really love this cleaner. I want to thank those I have been in contact with at Miele for sending the rep to my home to look at the issue first hand. Not sure many companies today would even take the time, or seriousness of the issue. Best I would expect from any other company, would be a replacement hose sent over and over. Doubt most companies would take 1 persons claim of a defect seriously as Miele has in my case. Will let you all know how I fair with the 3rd hose... even t hough I'm half tempted to not use it on high power again to prevent any stress, I suppose that defeats the purpose of having this high quality cleaner. If #3 fails, I'll just continue to work with Miele. Best, Andrew |
Post# 80310 , Reply# 36   9/7/2009 at 16:23 (5,343 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 80326 , Reply# 37   9/7/2009 at 17:30 (5,343 days old) by arh1953 ( River Park, in Port St. Lucie, Florida)   |   | |
Post# 82367 , Reply# 38   10/14/2009 at 15:33 (5,306 days old) by vacfanatic (Omaha, NE)   |   | |
So I've been extremely patient with Miele regarding the 2 hoses which have failed, and have resulted in me having this 9 month old vacuum being unusable for 6 weeks while waiting for the new hoses. Then I had the pleasure of wasting my own gas to drive across the city to the dealer, exchange the hoses both times. Why did I buy a $1000+ vacuum again? Miele's solution to the problem? It was suggested that I use "quick stokes" on my microsuede couches and curtains to keep the air flowing through the hose so that it won't screw it up. What about extended use with the crevice tool and Turbo Tool? How am I supposed to spare the hose of that backbreaking duty? In summary, I'm fuming pissed off. I sent an email to the district manager for Miele Floorcare on Friday, and I have YET to receive a response. I've got a 500 page email trail that I am pretty much fed up with. I've asked for a full refund of the S7 purchase price, or exchange it for a new in box Capricorn with SEB-236 which I idiotically SOLD and took a voluntary $300 loss to "Upgrade" to this S7 piece of shit. Please, someone kick my ass now, and don't over'do it on your hoses for you S7 owners. You'll be in the same boat as I am. With 3 months left of the 1 year warranty on the hose, what does Miele think I'm going to do after my 1 year is up? They replaced my SECOND failed hose with a THIRD hose, which again I had to wait 3 weeks for it to come in, then drive down to pick it up. Let's think about this for a second - replacing shit, with shit, is not a solution to the problem. They need to accept there is a design flaw with this hose, and deal with it. I want my money back - and I'm not your average vacuum customer who does not know squat about vacuums. Glad to know I've got $1000+ of my hard earned cash invested in this otherwise fine cleaner with a unreliable hose. I actually have the S7 boxed up, ready for Miele to actually do something about this, and have replaced it with a Dyson DC25. If I don't hear from them by Friday, I'm going to their corporate level on Monday, and I'll ask one of my good friends to write someting on his popular blog about the experience... Not only have I heard of others having the same hose issues, Jack even tried the squash test on his own S7 hose and guess what, it SQUASHES! Over time, normal use and "squashing" and stress causes the hose to fail. First hose lasted me about 6 months, second one, 2 months. Warranty is up in Jan 2010, and I've got to get rid of this now before I'm stuck with $70+ hoses and 3 week import times for the "forever better" 20 year lifespan this thing is estimated for. Pissed in Omaha, Andrew |
Post# 82374 , Reply# 41   10/14/2009 at 19:12 (5,306 days old) by vacfanatic (Omaha, NE)   |   | |
Brett, I agree with you on a few points. I suppose it was my stupid idea to even sell my Capricorn before I had a chance to use the S7, but I took the plunge. Having trusted that the S7 would not let me down because I did like the S5 so much... clearly I wish'd I'd of kept what I had! I've also had a lot of fluff etc build up in the brushroll springs, and the cord is a nice length but it's hard to get it all to fit on the hooks. Another minor but annoying thing is that dust and fine dirt can get behind the LED light lense. Why is that not sealed? I noticed the same thing on my SEB-236 on my S5. Maybe I'm a vacuum snob, but for the price I paid, I'm extremely unhappy. I should not have even had to so much as think about a part exchange on this S7, let alone 2. Do I have any confidence that the 3rd hose, which is the exact same part that the first and second ones were will last? Not a chance. Miele has my $1000+ and I'm stuck with what I consider a vacuum with a lemon of a hose. What good is a vacuum with a jank hose? Maybe I can retrofit a $40 Wal-Mart vacuum hose on the $1000+ S7 Vacuum, that'll fix it! Every product has it's fault, but the simplest of things, the hose, is inexcusable for such a high cost elite brand of cleaners. Andrew |
Post# 82376 , Reply# 42   10/14/2009 at 19:28 (5,306 days old) by vacfanatic (Omaha, NE)   |   | |
I figured that if I packaged it back up and said my vacuum prayers, that the hose would heal itself. Ok, not really. I'm just waiting for my request to have my money refunded. Anytime Miele... I've been dealing with the hose problems since about March 2009, and my patience is GONE. I have 3 months of warranty left before I would be expected to buy the new hoses that fail, fail, fail... better start a savings account! Andrew |
Post# 82383 , Reply# 44   10/14/2009 at 21:29 (5,306 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 82402 , Reply# 46   10/14/2009 at 23:16 (5,306 days old) by bimmer740 (Long Island, New York)   |   | |
I completely agree with "luxlife". I have had great success when dealing with a company when I can rattle off all the dates and names of all the people I have spoken with, and how many times I have spoken with each one. I usually start out fairly nice, and as soon as I start getting some generic bull shit answer I really give them hell. You are the customer and no matter what you have paid for the item, you should be accomidated in every possible way, and in a timely fashion. If you can speak to every possible supervisor you can, thats a plus too. Those who are higher up in the company will certainly want to please you once they understand how many people you have already dealt with. Maybe because those "higher ups" are trying to please the customer or because they are embarressed by the lack of action taken by their staff. Demand an immediate resolution to your problem from them. I have had several Miele canister and my last two, a Blue Moon and Red Velvet, were absolutely wonderful. Its a shame to here what an awful experience you are having with your machine, I thought for sure it would be as terrific as the Miele canisters. Good Luck! |
Post# 82408 , Reply# 47   10/15/2009 at 08:12 (5,306 days old) by vacfanatic (Omaha, NE)   |   | |
The local dealer is completely aware of what has been going on, and has never bothered to call me or follow up. In fact, the string of emails that have been going back and forth between Evy Daniell and myself for about 2 months, they have been CC'd each and every time. I realize the hose is defective, and I could care less about their redesign timeframes etc. I'm ditching this S7. I'm not going to take my chances again, on the same problem part that will fail again, just as my warranty goes up. They'll really tell me to shove it then and expect me to pay for the part after the 1 year warranty is up. Even having been suggested I should use "short strokes" to keep the airflow moving in the hose, is rediculous. That's like buying a 7 series BMW for about $100K and then the dealer telling you "Well, we've replaced your engine 3 times, we suggest you don't press the accelerator more than halfway down to prevent stress on the engine..." I've sent another email to them this morning, advising my next step is opening a complaint with Better Business Bureau. I agree that the canisters are much better than this upright, but at this point, Miele just sounds like a dirty word to me. Very frustrated!!!!!!!!! Andrew |
Post# 82409 , Reply# 48   10/15/2009 at 08:54 (5,305 days old) by vacfanatic (Omaha, NE)   |   | |
I decided to go ahead and get the BBB complaint filed for a refund. They have wasted enough of my time. Wish me luck everybody, and thanks for listening. It's been very frustrating, especially with the money I spent and lost on this so called "upgrade" to the new S7. Complaint Submitted Your complaint has been submitted. The complaint has been transferred to the local BBB to be handled in their system. You may wish to copy or print this information for further reference. Press OK when ready. The complaint is being handled by the BBB listed below. Please contact them with any questions. BBB of New Jersey (Trenton, NJ) 1700 Whitehorse Hamilton Square Road Suite D-5 Trenton , NJ 08690-3596 Phone: (609)588-0808 Fax: (609)588-0546 Email: info@trenton.bbb.org Web: www.trenton.bbb.org/... |
Post# 82412 , Reply# 50   10/15/2009 at 09:40 (5,305 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
The squeaky wheel gets the grease. Keep up the pressure, Andrew. Be polite and reasonable and deluge 'em with your pile of evidence in email and picture form. Feel free to use my pictures as well - I'll get more when I have a chance to visit the Miele stores in London and Kitchener and perhaps the T&A outlet in Sarnia over the weekend. Other members here that own S7s can help out by inducing this hose flattening and post pictures for Andrew's files. We've read about your hose problem for many months, another overseas member posted that his hose does the same thing and the display/demonstration model at Canadian Tire here in Stratford shows the signs of deformation and can be induced to collapse flat in the same fashion - clearly the hose used on this otherwise fine upright is a poor engineering choice. It is difficult to believe that this flaw didn't show up in Miele's much hyped R&D testing, being as this was Miele's first foray into producing their own in-house upright. Many other vacuums use this type of long stretch vinyl hose - such as the new Connie or the Kenmore Premalite - which do retract themselves toward the vacuum under throttled suction, but they do not permanently distort and flatten themselves like a runover snake in the road. The S7 hose does not return to a tubular form but takes on an oval cross section set. I trace the problem to the use of a cheaper weaker sub-standard wire used for the reinforcing coil. I agree with John Luxlife that this was a rushed "design on a deadline" - witness also the unnecessary protruding tab on the filter grill that catches on the underside rims of chairs, low cabinetry and coffee tables. I'm surprised that a google search hasn't turned up more complaints wordwide. Dave |
Post# 82416 , Reply# 51   10/15/2009 at 11:33 (5,305 days old) by luxlife (Under a Pecan Tree)   |   | |
I'm sure Miele already has their next more highly evolved upright model on the drawing board. Their last two major hose issues involved electronics and moving parts. No one talks about these particular problems anymore, but I remember they were a nightmare for my dealer. |
Post# 82417 , Reply# 52   10/15/2009 at 12:25 (5,305 days old) by vacfanatic (Omaha, NE)   |   | |
Post# 82422 , Reply# 54   10/15/2009 at 18:18 (5,305 days old) by vacfanatic (Omaha, NE)   |   | |
DONE. Miele asked me to drag the whole cleaner down to have it looked at, completely ignoring my request for refund or exchange to a different model for the LAST time. Dealer didn't call me back as they said they would tonight, I called back, no answer and left a voicemail. Called them back again when I got home, and he'd convinently "left for the day". Screw it! That's the last Miele product I ever buy, and you've all been warned how horribly they acknowledge my requests. I called Evy Daniell and left her a voicemail asking her to call me, but what does she do? Leaves me some canned email about needing to bring it in for review, again completely avoiding my request for exchange / refund. Life is short, and my blood pressure is not worth the $350 loss. I've offered the cleaner (with a freshly replaced PISS POOR hose) to a prospective buyer for just over $600. I'm so done with this. Good luck on all the S7 owners out there, my experience was nothing short if being dicked around for several months with no response to my needs as a customer of some "elite" brand of appliance. The sooner this piece of shit is out of my house the better. Andrew |
Post# 82429 , Reply# 55   10/15/2009 at 19:33 (5,305 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Andrew, cutting your losses and giving up is exactly what the Management 101 Rulebook hopes a disgruntled customer will do - give up and go away. Now the Better Business Bureau will file your complaint in thei,r dead file drawer. You should message 'Evy Daniell' that you will only agree to send the vacuum for evaluation at her expense as you are on record as this being the third hose to go bad, etc, etc, etc... Too bad I ain't in Omaha. Hell, I'd drive me and that vacuum to her office building at 9AM in the morning making it clear I ain't leaving until she sees me and hears the story...and so on. Make yourself a constant steady droning nuisance and she'll deal with you or shoot the dispute even further up the chain of command. Dave |
Post# 82444 , Reply# 57   10/16/2009 at 02:24 (5,305 days old) by kirbyultimateg (Troy Ohio 45373 USA)   |   | |
Andrew, I am so sorry to hear about this! Rob Gwisdala ps: I thought that Miele used to be a reputable name! |
Post# 82449 , Reply# 58   10/16/2009 at 08:23 (5,305 days old) by vacfanatic (Omaha, NE)   |   | |
Friends, Not to worry, I've updated the case with the Better Business Bureau with the rigamarole I was dealt yesterday. My prospective buyer has alerady purchased a new cleaner, so I'm stuck with this fabulous S7 with a Dollar General hose until I get my money back from OK Sewing with the help of BBB, or sell it on my own terms. Wish me luck. I'd hate to think how I'd be treated had I of purchased a $3000 Miele washer which the door falls off every 3 months, or a $7000 Miele Stove that shoots flames directly on the cake you are baking... Not backing down, it's with the BBB now. If no resolution, Nebraska Atorney's General is next. Rediculous! Former Miele Customer, Andrew |
Post# 82452 , Reply# 59   10/16/2009 at 11:00 (5,304 days old) by luxg ()   |   | |
Good for you Andrew!!!! |
Post# 82453 , Reply# 60   10/16/2009 at 11:35 (5,304 days old) by vacfanatic (Omaha, NE)   |   | |
Well I received an email from Evy and she advised that OK was willing to offer an exchange. Why didn't the tell me that when I asked about 5 times ago? I felt as if I was being dragged along, to have my S7 taken in to be inspected, to be told that "well, you're on the 3rd hose, see how it does, cleaner checks out ok!". It's been so frustrating, and I really hope they offer the exchange. I've asked the Dealer to call me back today to let me know what we can work out. A person can only take so much, and this has pressed me to my limit. I'm human, and having spent approximately $2200 give or take with this dealer / Miele products, I was livid. If this is resolved, I'm willing to clear the table and continue my business with OK Sewing and Miele. If they don't offer the exchange, I'll have no choice but to keep my BBB case open. I just want resolution as I've been asking for a month. I'm the customer, it's not fair to have me be stuck with their product which has clearly been nothing but trouble for me, when all I'm asking is to have it taken back for a different model. I believe this falls into the topics of Customer Service and Exchange. Wish me luck guys. Thanks, Andrew |
Post# 82457 , Reply# 61   10/16/2009 at 12:13 (5,304 days old) by vintagehoover ()   |   | |
Good luck, Andrew! :D |
Post# 82462 , Reply# 63   10/16/2009 at 15:03 (5,304 days old) by vacfanatic (Omaha, NE)   |   | |
Customer service... what is customer service? I'll tell you what I call customer service! I bought a $100 Vornado Heater which was 2 months from being expired on it's 1 year warranty. The switch had shorted out and would not work right. I emailed Vornado, they provided me an email response in 24 hours with a link to the pre-paid shipping label. Dropped off the heater, and it was returned to me in 12 business days. The fan had been completely cleaned, circuit board / switch and cord replaced, repackaged and overnighted to me. It does not stop there. They provided me a customer appreciation packet, with a letter of apoligy which was HAND SIGNED, a 30% off coupon for my next purchase of any item with no expiration date on the coupon, AND they renewed the 1 year warranty. $100 product experience vs. Miele's $1000+ product experience... Need I say more? Andrew |
Post# 82473 , Reply# 64   10/16/2009 at 19:43 (5,304 days old) by vacfanatic (Omaha, NE)   |   | |
Well I've done all that I can and have expressed my concerns to Evy. I'm just going to wait for a few days until I hear via email or phone on what the resolution will be. I'm going to try and just relax and enjoy my weekend and not stress over this any further. Since this thread is turning more into a book / blog, I thought I'd at least let you all know that I have not yet jumped off a bridge to relieve myself of this disaster. :-) Andrew |
Post# 82477 , Reply# 65   10/16/2009 at 20:35 (5,304 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 82500 , Reply# 66   10/17/2009 at 18:01 (5,303 days old) by vacfanatic (Omaha, NE)   |   | |
I am so thankful that I got this issue settled. I went today and returned the S7 and swapped it for a brand new sealed S5 Leo with the SEB-217-3. I'll upgrade to the SEB-236 again later on but I just wanted to be done with it. They threw in a free box of bags for me and we shook hands and cleared the table of all our disputes. I'm just glad I didn't get stuck with that lemon S7 I had. The dealer advised it was being sent directly back to Miele for research to see what could have been causing the hoses to fail. It's obvious it's not the cleaner, but they can do whatever they want with it now! Good Riddance! At first I was not sure about the color of the Leo, it's Sapphron Yellow, but it's growing on me each time I look at it. I'm back in business now, and I hope that I never have to deal with something like this again! Andrew |
Post# 82501 , Reply# 67   10/17/2009 at 18:02 (5,303 days old) by vacfanatic (Omaha, NE)   |   | |
Post# 82507 , Reply# 68   10/17/2009 at 20:49 (5,303 days old) by cart1531 ()   |   | |
I'm glad you were able to sort everything out, Andrew. I love the Leo, that is a very nice shade of yellow. I've really liked the Miele canisters that I've used, I'm hoping that Santa will bring me one this Christmas lol. |
Post# 82522 , Reply# 70   10/18/2009 at 10:38 (5,302 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 82524 , Reply# 71   10/18/2009 at 11:59 (5,302 days old) by xraytech ()   |   | |
Andrew, am so glad to hear that they finally decided to correct their customer service issues and that everything wrked out for you. |
Post# 82527 , Reply# 72   10/18/2009 at 12:37 (5,302 days old) by williamr1248 (USA)   |   | |
Hey I just love that different color. Glad you got your problem fixed. |
Post# 82541 , Reply# 74   10/18/2009 at 15:48 (5,302 days old) by countryguy (Astorville, ON, Canada)   |   | |
Post# 82542 , Reply# 75   10/18/2009 at 15:49 (5,302 days old) by countryguy (Astorville, ON, Canada)   |   | |
Post# 82551 , Reply# 76   10/18/2009 at 18:23 (5,302 days old) by vacfanatic (Omaha, NE)   |   | |
Thanks everyone who kept me from jumping off the bridge while this issue dragged on and on and on LOL. Life is too short to get bent out of shape over a vacuum cleaner - probably shouldn't have been so pissy about it but my patience was maxed out. At least I know the S5's are great cleaners, and the hose on it will NEVER "smush". I've been busy vacuuming with the new Leo this weekend. Wonder how those new carbons are seating! Wish I had a picture of a Miele Vortex motor cutaway like Jack found of that DC24 motor. If anyone has one let me know! Andrew |
Post# 82559 , Reply# 77   10/18/2009 at 20:59 (5,302 days old) by kirbyultimateg (Troy Ohio 45373 USA)   |   | |
Congrats Andrew! I am so glad that Miele finally took care of you! |
Post# 82611 , Reply# 78   10/19/2009 at 15:39 (5,301 days old) by dial-a-nap (Omaha - the home of the TV Dinner)   |   | |
Andrew, I'm glad you got the vac you wanted. FWIW to the others following your postings, I'll repeat the bit if info I know about OK Sewing and Vacuum to offer a little more insight and stand as witness that Andrew isn't a drama-prone shopper ;-) I would loved to have been a fly on the wall when the call came from Miele to OK S&V ordering the exchange of your vacuum! My mother belongs to two different quilting groups (or guilds) and the reputation is, and has long been, that OK Sewing and Vacuum is one of the hardest dealers to get good service from. Terms like rude, belligerent, uncaring and indifferent have been thrown around very frequently about OK. I recently was given a non-working, 80's Pfaff sewing machine at an estate sale and when I told my mother about it, she said "Don't take it to OK for repair - go anywhere else but there." I bought a yellow Miele Solaris vacuum there a number of years ago and other than the initial sales pitch in the store and the walking out with my box of Miele, I had no other interaction with them. I'm a Bernina sewing machine person and Pfaff machines are available in a couple of other places now (they used to be exclusive to OK years ago) so there is no need for me to shop there although they do have a very cool collection of sewing machines displayed very well in the store. Being a Miele dealer for vacuums and now all major appliances, I would think they might have been schooled in some positive customer service skills prior to and as a condition of maintaining their dealer status. Apparently this is not the case with any of the product lines they sell. (Sebo & Windsor, Pfaff, Janome and Miele) With the nature of the high-end sewing and high-end vac businesses, I would think repeat customers would be a significant portion of their revenue so I'm surprised they have earned such a poor reputation but this is not much different than the others I've heard. Lessons learned in lives lived, I guess we locals have our testimony to OK Sewing and Vacuum. That new yellow is just gorgeous, BTW! |
Post# 82626 , Reply# 79   10/19/2009 at 18:07 (5,301 days old) by vacfanatic (Omaha, NE)   |   | |
Greg, Well I'm a pretty level headed individual, but this sure as hell tested every bit of patience in my 27 year old body. I honestly can't blame OK completely for the ordeal, as a lot of the miscommunication issues came directly from Miele. However, I will be a eighty below zero day in hell before I purchase another Miele vacuum from OK... They really screwed themselves on this because I have been discussing replacing a few of our appiances in the house with Miele down the road. (Dishwasher and Washer/Dryer). Apparently my near $2500 in business with OK does not bring me up to a high enough status to receive return calls etc, nor qualify me for any form of customer service. They did give me a free box of bags when we did our final business exchange... I can't help but think they should have loaded my trunk full of bags though. :-) I do love the new S5 though, and I'm happily resuming life in the vacuum lane! Andrew |
