Thread Number: 6787
What is the best thing to use to remove scuffs |
Post# 74933   7/10/2009 at 22:17 (5,402 days old) by thevacuumman (Borger, TX)   |   | |
because i am trying to remove scuffs off of my concept one |
Post# 74935 , Reply# 1   7/10/2009 at 22:22 (5,402 days old) by xraytech ()   |   | |
magic eraser |
Post# 74936 , Reply# 2   7/10/2009 at 22:39 (5,402 days old) by kirbfan94 ()   |   | |
Most defintaly a Magic eraser. |
Post# 74938 , Reply# 3   7/10/2009 at 22:57 (5,402 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 74939 , Reply# 4   7/10/2009 at 22:59 (5,402 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Mister Clean Magic Eraser Original or a similar generic knockoff such as Target sells. New Improved Mr Clean versions just cost more and work less well for our restoration purposes. I prefer the generics on price alone as all these 'miracle sponges' compress and crumble under the hard persistent scrubbing such scuffs require and you go though a lot of them on other projects and surfaces when you realize how great they are. I break them in half, dampen with ordinary tap water, wring dampdry and apply plenty of elbow grease. The results will amaze you. The surface will end up with a slightly dulled appearance that can then be restored with a Mothers Mag polish treatment. Heck, ordinary car paint wax does a good job, too. Never use a kitchen scouring pad or regular sandpaper in an attempt to remove surface marring or minor scratches; even fine emory paper abrades the surface material. If that's what you think is required after Magic Eraser-ing then a buffing wheel and plastic polishes are the way to go for deep scratches and a high shine. These are the two Mother's polishes I use. Mag and Aluminum polish is the one I use on all metal vacuum parts and trim, first applied and worked with 0000 steel wool, switching to a soft cloth for final polish after a ride on the buffing wheel. Billet Metal Polish contains half as much and costs twice as much but contains some amnazing non-silicone additive that leaves behind a subtle residual coating that when buffed with a cloth banishes tarnish and dulling and repels dust. I use it on very special hammertone painted vacuums and polished trims and it's ideal for plastics - far shinier than any wax (including the best Museum Archival micro waxes) and has no discernible tactile feel under the hand such as wax does, ie...fingerprints. Dave |
Post# 74963 , Reply# 6   7/11/2009 at 09:58 (5,402 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 75049 , Reply# 7   7/12/2009 at 02:33 (5,401 days old) by retardturtle ()   |   | |
isnt there 2 diff kinds of BON-AMI..i know one is great for windshields...is that the one? |
Post# 75148 , Reply# 8   7/12/2009 at 20:56 (5,400 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 75179 , Reply# 10   7/12/2009 at 23:51 (5,400 days old) by vacman117 (Chicago, IL)   |   | |
