Thread Number: 6526
Royal Metal Vacuum Upright - oil? |
Post# 72412 , Reply# 3   6/17/2009 at 12:42 (5,418 days old) by atrac (United States )   |   | |
Thanks for the advice! I was SO close to putting WD-40 in there. Glad I didn't! :) |
Post# 73193 , Reply# 5   6/25/2009 at 21:24 (5,409 days old) by tristar ()   |   | |
Read Above... Normal 3-in-1 oil does gum. The MOTOR variety does not. It's explicitly designed for sleeve motor bearings. |
Post# 73216 , Reply# 8   6/25/2009 at 22:58 (5,409 days old) by louvac (A)   |   | |
I said, SAE-30 NON DETERGENT OIL.....It's out there, I've used it and it works......and I have never had a problem....But...whatever works for you....... |
Post# 73366 , Reply# 10   6/27/2009 at 00:55 (5,408 days old) by atrac (United States )   |   | |
Thanks again for all of the info! And extra kudos to Louvac! ;) |
Post# 73380 , Reply# 11   6/27/2009 at 07:13 (5,408 days old) by vinvac (Dubuque IA)   |   | |
Louis is correct! At the convention, Mike Rogers did one of the clinics and non-detergent SAE 30 oil is what he suggested you use. Louis is quoting word for word what Mike told us. Most lawn mowers, if you read the manual, tell you to use SAE 30 Non-detergent oil. Unless of course you are using a good mower such as a Lawn-Boy...then you would use their brand of 2 cycle - ashless oil. Morgan |
Post# 272324 , Reply# 13   3/17/2014 at 22:18 (3,683 days old) by kevin (Livonia)   |   | |
Ad found on eBay (couldn't enlarge--sorry): |
Post# 451149 , Reply# 14   3/29/2022 at 10:29 (750 days old) by StephanB9 (airwayheights)   |   | |
Sorry to revive a long dead post but I have information directly from the user manual that came with my Royal 993 and 880. According to the book it says to use sae 30 motor oil and not to use thin or sewing machine type oils.
