Thread Number: 6299
brushroll...
Post# 70285   5/24/2009 at 21:12 (5,444 days old) by retardturtle ()
in your opinion and exp...who makes the 3 best agrsv brushrolls to date and on what vacuums are they on....issue; heavy traffic short pile carpet.
Post# 70288 , Reply# 1   5/24/2009 at 21:35 (5,444 days old) by tristar ()
It depends. Is the carpet glued down or does it have a pad behind it?
If the carpet has a pad behind it, you can't beat a modern Sanitaire with a VGII brushroll installed. They've got the airflow and the vibration to get the dirt and grit loose. Nothing will clean a high traffic carpet like the combination of airflow and agitation. An older Hoover with the beater bar agitator will work well too, although I'm assuming you're wanting a daily-driver, hence the Sanitaire suggestion. A good sweeper won't help you here. Agitation is essential to get the "crud" out of the backing of the carpet.
Unfortunately if the carpet is glued down, you'll need a good sweeping action since vibration will do nothing for you there. In the glued-down case, pretty much anything that sweeps will do about the same job since airflow can't get behind the carpet to clean from below. At my work we actually use an older plastic-based Hoover Convertible with a Cleveland Wood Products 4-row brushroll. It sweeps well and has just enough airflow to clean the glued carpet, but not so much suction that it seals to the floor.
Post# 70291 , Reply# 2   5/24/2009 at 21:50 (5,444 days old) by vacman117 (Chicago, IL)
Vibra Groomer
vacman117's profile picture
the vibra groomers are very good.
Post# 70327 , Reply# 3   5/25/2009 at 08:20 (5,443 days old) by queeny77 (berwyn,IL)
queeny77's profile picture
vacuums with stiff brush rolls would be oreck xl 21 and hoover windtunnel.(my preforence non self propelled bagged).
Post# 70341 , Reply# 4   5/25/2009 at 16:13 (5,443 days old) by retardturtle ()
brushroll
i have a vac...a panasonic 583 except w a triforce mtr....but im working on trying to find the ultimate brushroll to use on it...i can pretty much modify one that will last for years....i also have a riccar 8925..i hav access to a triforce roller 3 full rows..riccear 2 row comcl...pretty much all of them mentioned by u guys...just gotta b a 12in roller..im open to any and all ideas...i dont want to just hack stuff up,i kinda want a plan...im about 2 start a project with my own tandem air vac...and the carpet in question is padded very light tan apartment grade carpet.
