Thread Number: 61
Worst I've Seen - |
Post# 462   9/1/2006 at 19:42 (6,418 days old) by dial-a-nap (Omaha - the home of the TV Dinner)   |   | |
I found a Sanitaire at the thrift shop about a year ago and used it for a while but got frustrated with it because no matter what I did or what belts I used, the beater bar kept stopping on most any carpet. A while back I ordered parts from Hesco and replaced the fan and pulley/shaft. You can see the difference in the two parts and needless to say, the new one solved the problem...
Post# 470 , Reply# 1   9/1/2006 at 20:22 (6,418 days old) by hoover1060 ()   |   | |
Now thats got some miles on it!! I never would have thought a belt pulley would wear down, but DAMN!! |
Post# 474 , Reply# 2   9/1/2006 at 22:41 (6,418 days old) by convertible68 ()   |   | |
Wow, how incredible; never thought that could happen! Might have to check out the one on the SC899 while I'm at it... |
Post# 483 , Reply# 4   9/2/2006 at 00:37 (6,418 days old) by seamusuk (Dover Kent UK)   |   | |
We used to see quite a few Juniors with this problem, they usually came in for the belt coming off all the time.The cause being a worn belt sounds reasonable to me! Seamus |
Post# 484 , Reply# 5   9/2/2006 at 01:30 (6,418 days old) by swingette ()   |   | |
those outrageous 7amp motors dont help much. 7 amps is TOO MUCH! make it 5 amps, please. |
Post# 485 , Reply# 6   9/2/2006 at 01:38 (6,418 days old) by compactc9 ()   |   | |
Just use a geared belt. If only they could figure out a way to put a geared or poly V belt on a Sanitaire. It would be a HUGE improvement. |
Post# 493 , Reply# 7   9/2/2006 at 09:26 (6,417 days old) by rogera608s (Tucson, AZ)   |   | |
Greg, Finally an answer to the problem. I never thought pulley wear would matter that much. |
Post# 498 , Reply# 8   9/2/2006 at 12:35 (6,417 days old) by dial-a-nap (Omaha - the home of the TV Dinner)   |   | |
I was shocked to see it too, I've seen several machines that have been used in commercial settings with a lot of sand, etc. (common particularly in the winter with sand and salt on walks, landings and stoops) and you can see the wear and tear on the machine parts from the sand moving through the beater and air-paths. Your theory on the worn/dirty belt would make sense, Reggie, especially given enough time using it this way.
Post# 420856 , Reply# 10   3/1/2020 at 02:21 (1,489 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
I had an idea in the way that this happens. It is because it is a dirty fan cleaner, and all the dirt and debris passes through the belt and pulley to get into the bag. When the belt gets dirty with a lot of sand and grit, then through friction it rubs on the pulley - it's like a sanding machine and is gradually filing down the pulley post.
I accidentally killed my Panasonic's vacuum belt by picking up too much dog food that spilled on the floor - it made an abrasive and sawed a hole in the belt and it tore in half. I would have never ever thought to look for this on these vacuums - I assume this is an extreme case - but I was getting so frustrated with a couple of Convertibles and a Eureka that would not have the belts stay on - I kept thinking the new belts were too old or I had the wrong size. |
