Thread Number: 6052
TriStar CXL |
Post# 67734 , Reply# 1   4/25/2009 at 23:10 (5,476 days old) by kirbyotronic ()   |   | |
Other side... |
Post# 67735 , Reply# 2   4/25/2009 at 23:11 (5,476 days old) by kirbyotronic ()   |   | |
Post# 67736 , Reply# 3   4/25/2009 at 23:11 (5,476 days old) by kirbyotronic ()   |   | |
Post# 67737 , Reply# 4   4/25/2009 at 23:12 (5,476 days old) by kirbyotronic ()   |   | |
Post# 67738 , Reply# 5   4/25/2009 at 23:13 (5,476 days old) by kirbyotronic ()   |   | |
Post# 67739 , Reply# 6   4/25/2009 at 23:13 (5,476 days old) by kirbyotronic ()   |   | |
Could use a little cleaning... |
Post# 67741 , Reply# 7   4/25/2009 at 23:14 (5,476 days old) by kirbyotronic ()   |   | |
Everything! |
Post# 67751 , Reply# 8   4/26/2009 at 10:13 (5,475 days old) by ridgidvac ()   |   | |
Nice Tristar vac. How old is that 1 |
Post# 67754 , Reply# 9   4/26/2009 at 11:49 (5,475 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
There are more clues in the Serial # and the decal. What does it say on the bottom for Model No?. Score! with all the gold flecked transparent tools to join your Compacts. I don't see it but I will assume you have the inner cloth bag with the rubber sealing ring? Discussed before that the power pin sockets are brass/bronze tubes open along one side. They can be squeezed gently with vice grips or slide a pin or small nail in along side it to crimp it closed a little. If the connection is still intermittent then a continuity test with the ohm meter on your circuit tester will locate which section has the break. Check the hose and PN electrics on any other 2 pin vacuum you have. Would really like a sharp direct on closeup of that intact decal on the side, please. Usually those get rubbed off. Is it labeled an Anniversary Model? 'As New As Tomorrow', I see a highwing monoplane and a two engine prop job... Dave Here's the matching colour schemed 50th Anniversary Tristar. |
Post# 67755 , Reply# 10   4/26/2009 at 11:52 (5,475 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 67757 , Reply# 12   4/26/2009 at 12:45 (5,475 days old) by kirbyotronic ()   |   | |
Forgot to post this picture! Happy now, guys??? ;) ~Alex |
Post# 67760 , Reply# 13   4/26/2009 at 14:14 (5,475 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
FANTASTIC and WIERD! a Piper Cub, a heavily armed to the teeth prop fighter and a Hunter Sub in the foreground while 'something else', perhaps the SEAVIEW, is launching an ICBM. Not seen that decal before - it's a keeper. I wonder if this was the Consumer model or was specially issued for a Naval Base? Rather frightening and unsettling for the average housewife? Thank you, Alex |
Post# 67821 , Reply# 15   4/26/2009 at 22:35 (5,475 days old) by kirbyotronic ()   |   | |
You asked about the bag Dave, so here's a pic just for the heck of it. |
