Thread Number: 6020
Miele S147 Stick Vac with Power Nozzle |
Post# 67419 , Reply# 1   4/23/2009 at 09:57 (5,453 days old) by sleepdoc (St. Louis, MO)   |   | |
I think you're experiencing normal operating feel for that machine. The upright is heavy in comparison to the wands that attach the nozzle to a canister. Also, the 217 nozzle has tiny wheels and isn't easy to push when it's bearing that much weight. I use that setup, and it works great, even though it's a little more work to push and pull it. The handle is adjustable on that vacuum. I found that I could make it more comfortable by experimenting with different handle lengths. You'll like that vacuum. Don't give up on it. patrick |
